ᐅ There is a draft coming through the front door if it is not properly closed or locked.
Created on: 5 Jan 2021 14:14
Tx-25
Tx-25
5 Jan 2021 14:14
Hello, what can I do about the issue mentioned above?
When we lock the door, it pulls more tightly against the frame and the problem is almost completely resolved.
The door is 6 months old. Is it common for an exterior door to be adjustable so that it presses more firmly? I haven’t found any information about this yet.
andimann5 Jan 2021 15:14
that depends on your front door and the hardware in the frame. In our case, you can adjust the position of the hardware by a few millimeters using eccentric cams, which allows you to press the door more firmly against the seals. However, this also means you will need to close it more firmly. Very easy closing and perfect sealing usually do not go hand in hand.
Andreas
11ant5 Jan 2021 15:21
Tx-25 schrieb:
Is it possible to adjust an exterior door so that it presses more firmly? I haven’t found anything about this yet.
When the door is open, you should be able to see adjusters for two axes on the hinges in the frame. At the very least, you will find a reference to the manufacturer there, who can replace guesswork with knowledge.
knalltüte
5 Jan 2021 16:21
Are there doors that lock automatically (so they don’t just latch but lock in a way that meets insurance standards)? Those are also airtight. We have those 😎.
Tx-25
6 Jan 2021 09:47
Unfortunately, there is no manufacturer information on the door.
However, I found the hardware manufacturer. The door does not seem to allow for a noticeable increase in contact pressure. Adjustments can only be made on the fixed frame where the door lock engages with the frame. I have pushed this part outward as far as possible and reattached it securely, hoping that the door will press more firmly outward when unlocked and thus close more tightly. When the door is not locked, it only closes through the cylinder. At the top and bottom corners, I can pull the door about 1 cm (0.4 inches) away from the frame by hand if I apply force.
I made the same adjustments on the two strike plates where the locking bolts engage. So the door also presses a bit more firmly when locked. All adjustments are limited to a level where the door can still be locked smoothly.
Nida35a6 Jan 2021 09:58
Buy a cylinder lock with a knob that locks from the inside every time; the colleague can still enter from the outside with a key. It is also a better panic lock, safer for children as well.
