ᐅ Is Installing Wood Fiber Insulation Above Rafters a Good Solution for Uninsulated Attics?
Created on: 19 Jul 2016 08:08
world-eHello everyone,
Does adding a wood fiber insulation layer above the rafters make sense for an otherwise uninsulated attic space (above two full floors)? I’m particularly interested in heat protection, etc. The top floor ceiling is going to be insulated. Thanks.
Doc.Schnaggls19 Jul 2016 09:45Hello,
this is how our roof structure looks as well.
The wood fiber insulation boards are definitely useful for heat protection – our attic isn’t exactly cool at the current temperatures, but it’s absolutely not comparable to the uninsulated attic in the old house, where in summer it often felt like being in an oven...
Dirk
Dirk
Sebastian7919 Jul 2016 09:58The question is what you intend to do with the pointed roof – of course, it provides better summer heat protection, but the cost is high and the effect is limited with your (presumably tent-like) roof.
We have it on a gable roof, which also benefits the upper floor – that’s why I would always choose this option.
Sebastian7919 Jul 2016 10:47OK, but that doesn’t change my opinion 😉
garfunkel21 Jul 2016 23:54Is it possible to use the attic space as living area at some point in terms of dimensions?
If not, I would probably avoid adding insulation above the roof. The rafters, which act as thermal bridges, can also be insulated separately.
