ᐅ Is our construction project feasible? Is our budget sufficient for it?
Created on: 11 Aug 2018 15:10
AndreasGMT
Hi,
I’m new here.
Regarding our plans, my wife and I are planning to build our single-family home within the next 1.5 years.
We have a plot of land that is expected to be designated as a building area next year. This is almost certain. The plot has a slight slope, so a basement will be necessary. Development costs will naturally be an additional expense.
We are planning a house of about 160–175 m² (1,722–1,884 sq ft), if it fits within our budget.
Our budget is approximately €430,000 for the house, development costs, additional construction expenses, kitchen, garden, and a carport (prefabricated garage), as mentioned, the land is already available.
As personal contribution, we can install interior doors, lay flooring, and fit windows, the front door, as well as roller shutters and blinds, since we will purchase these directly from the supplier at cost price and install them ourselves.
In your opinion, is this feasible? Is our budget sufficient?
Thanks in advance for your answers.
Grantlhaua
13 Aug 2018 09:41
Bookstar schrieb:
You’ll easily need 2000 liters of paint for the interior. What about the exterior? And plastering for 30,000 is unrealistic, even in rural areas.
We recently helped paint the interior of a house with almost the same square meterage. The cost for paint was well under 1000€ for a well-known brand. (Within the family, so the price isn’t exaggerated.)
For plastering, I have a quote in the mentioned price range. However, I am still waiting on two more offers.
niri09 schrieb:
We have a quote for a single garage (although oversized) for 9,500€ gross. A double garage at 35,000 is excessive; in that case, I would recommend continuing to search and negotiate.
One has to consider that we won’t get a concrete slab in the garage, only a reinforced ring beam, and we will do the paving ourselves, including inside.
hanse987 schrieb:
Electrical, satellite, and LAN aren’t listed yet.
The electrical work is not entirely clear yet, but the cost will likely settle around 20,000€ for a “standard” installation without extensive smart home features. We will also contribute a lot of the work ourselves since my brother and I have training as electronics technicians (although not specifically in building technology).
Grantlhaua
13 Aug 2018 09:44
niri09 schrieb:
It depends on whether insulation is planned for the exterior. We are paying for both interior and exterior work, drywall installation plus the ETICS insulation system for 45,000€ gross. The insulation alone costs around 21,000€ and can theoretically be deducted.
Our house has no insulation because we don’t have any requirements from KfW or similar programs. We use 36.5cm (14 inches) bricks and that’s sufficient. For 45,000€, I would plaster the walls myself. We could do it, but without the right machines, it’s a really tough job and would delay the entire construction.
@Bookstar
Since we are only building next year, I can’t say if there might still be hidden costs somewhere. But what I mentioned is currently confirmed in writing with the respective company.
You should also consider that we are managing individual trade contracts, so we don’t have exorbitant expenses for construction supervision or similar.
haydee
13 Aug 2018 09:47
Grantlhaua schrieb:
I can roughly tell you the major cost items off the top of my head. I’d need to check the list tonight for the total.
Additional construction costs (notary, insurance, utility connections, etc.) approx. 20,000
Shell construction 174,000
Roof including exposed roof structure in the garage and metal roof on the bay window 34,000
Heating (air-source heat pump with 1,200 l (320 gallons) buffer tank and underfloor heating throughout the house) 43,000
Central ventilation system 8,500
Kitchen 20,000
Flooring calculated at 50€/m² (5 dollars/sq ft) (self-installed, and we will probably choose one that’s even a bit cheaper)
Screed 5,750
Windows 20,000
External blinds 10,000
Garage door 3,100
Front door 6,000
Paving 5,000 (self-installed)
Bathroom fixtures and fittings 17,000
Fireplace 13,000
Wow, that roof is cheap. We’re paying 16,000 euros just for the garage (8 x 7 m (26 x 23 ft)) with an extension (12 m² (130 sq ft)) and a small basement (16 m² (170 sq ft))—including pitched insulation, waterproofing on the house and retaining wall, some sort of membrane on top, and the gutter.
haydee
13 Aug 2018 09:50
Check the offers to make sure they are still valid when you are ready. Usually, there is a disclaimer or condition attached.
Grantlhaua
13 Aug 2018 09:57
haydee schrieb:
Make sure to check that the offers are still valid when you get to that point. Usually, there is a reservation or condition.
In our case, most offers had an expiration date. There was never a reservation, but I wouldn’t have agreed to that anyway.
The roofer, structural builder, and plumbing company all come directly from our village, which might help a little since there are no travel costs and we know each other (which may not save thousands of dollars but certainly something).
niri09
13 Aug 2018 09:58
Grantlhaua schrieb:
We have no insulation because we don’t have any requirements like those from KfW,... 36.5 cm (14 inch) bricks are sufficient. For 45,000€ I would do the plastering myself. We could do it, but without the right machines it’s a really tough job and would delay the entire construction.
You unfortunately misunderstood, the 45,000 includes 21,000 for insulation, so it doesn’t actually cost 45,000 without insulation ;-)
ETICS (external thermal insulation composite system) is only used with calcium silicate blocks.
