ᐅ Is it practical to install a bathtub under a skylight?
Created on: 9 Jan 2018 18:30
jawknee
I’m currently working on floor plans and came across a point regarding the bathroom that I’d like to discuss briefly. The bathroom will most likely be located in the converted attic. This is a hipped roof with a 30 to max. 35 degree pitch, an 80cm (31 inch) knee wall, and the bathroom will probably have two sloped ceilings as a result.
To use the space efficiently (I plan to use the higher areas for the separate shower and washbasin) and also because I find it quite cozy (e.g., looking out while it rains or enjoying a light breeze in summer), I would like to place the bathtub directly under the roof window. Depending on the space for getting in, I would of course adjust the bathtub position accordingly, possibly with a built-up frame or drywall construction—or whatever is best practice—but that’s not the question here.
What I’m wondering is: besides the issue of ceiling height, are there any disadvantages to placing the bathtub directly beneath the roof window? I do see it often in pictures, but what is common practice isn’t always the best.
A few things that come to mind:
Will the window always be fogged when bathing so you can’t see out, or will water drip down the glass?
In winter, does cold air “fall” from the window and cause a draft in the bathtub when you are wet, or is that no problem with modern windows anyway?
Since I enjoy long and frequent baths, it’s important to me to avoid planning mistakes here.
I don’t have a floor plan to share yet, as I’m still working on the overall layout and for now just want to clarify this question to see if it’s even a viable option.
Thanks in advance for your opinions and experiences.
BOB der 1.10 Jan 2018 14:00
Hey,
first of all, have fun building.
The idea of skylights is nice; you might also like one with a fixed pane, so-called knee-wall windows.
Of course, condensation is the biggest concern for home builders, but it depends on roof insulation, exterior walls, etc.
We have two skylights installed on a 25-degree (25°) roof! No moisture at all, because the bathroom is kept at a minimum of 24°C (75°F).
Cleaning: sure, you should keep in mind that this could become a hazard. Getting into the bathtub is okay, but standing on a stool in the tub? Definitely not – that’s asking for trouble.
It also depends on how often you bathe! Our tub is simply too big… so it gets used less than expected.
Do you have underfloor heating? Additional heaters or just towel warmers… that should be clarified regarding heat distribution.
I think you’ll get many more tips… my advice: go for it, a little bit of luxury is necessary.
jawknee
10 Jan 2018 15:07
Hey, thanks in advance for all the tips.
Regarding the height, of course, you’d probably have to move in a bit. But I think having a small shelf on the edge would be quite practical, or maybe adding a small wall, so from my point of view, that’s the lesser issue. I also want to check out some show homes with tubs like this to get a better sense of the ideal height.
As for cleaning, I’ll have to see how to manage that without risking injury—thanks for the advice. But I think it can be handled. And I’m not really a fan of cleaning anyway, so that balancing act won’t be a weekly event.
Underfloor heating is definitely planned, but no additional heat sources.
Mycraft10 Jan 2018 16:27
Then, depending on the size of the bathroom, the heating capacity might be just enough or insufficient.
jawknee
10 Jan 2018 17:41
Oh, really? Is the underfloor heating that weak there?
Joedreck
10 Jan 2018 18:34
Yes, but then there is additional wall heating. It’s no problem at all.
toxicmolotof
10 Jan 2018 19:02
Advantage: If you forget to close the window and a storm occurs, the water can drain away directly.
