ᐅ Is it possible to install Ikea Brimnes furniture without damaging the wall?
Created on: 15 Nov 2022 08:36
timparHello everyone,
I am planning to set up some furniture from the Ikea Brimnes series in my apartment. However, it is important to me that the walls are damaged as little as possible during assembly and later use, since I live in a rental and want to avoid leaving any marks when I move out.
My question is therefore: Is it possible to set up Ikea Brimnes furniture without damaging the walls? Are there special mounting methods, alternative fixings, or tricks to protect the walls? I have heard that attaching the furniture to the wall for stabilization can be particularly problematic.
I would appreciate any tips and experiences on how to secure or place Brimnes furniture in a way that avoids holes or paint peeling while ensuring the furniture stands safely.
Thank you in advance!
Hello timpar,
First of all, it is important to understand that Ikea Brimnes furniture often comes with wall fasteners (e.g., anti-tip devices) which are actually required to ensure safety. These fasteners are usually designed to be anchored into the wall using wall plugs and screws. Naturally, this will result in holes in the wall.
If you want to avoid damaging the wall, you can consider the following alternatives:
- Using non-slip pads under the furniture to stabilize it without wall attachment
- Spacers that stabilize the piece without being directly screwed into the wall
- Temporary tension rods or clamps if you have sufficient ceiling height and structure
Warning: Without wall fasteners, there is always some risk of tipping, especially with taller or heavier furniture, particularly if there are children or pets in the home.
If you do decide to use the wall, make sure to use high-quality wall plugs that leave as little residue as possible when removed. Drywall is more sensitive than solid walls.
Summary:
- Completely damage-free installation on the wall is difficult
- Use alternative stabilization options
- Always consider safety requirements
If you like, I can also provide a step-by-step guide on how to properly secure the furniture, but this will of course depend on the condition of your walls.
Summary:
Marlenepa15 Nov 2022 11:03Hello timpar,
I would like to join the conversation and look at your question from a slightly different perspective. You are absolutely right that avoiding wall damage is a very important issue, especially in rental apartments.
Ikea Brimnes furniture is designed to be secured to the wall using anchors that require drilling holes. However, there are ways to minimize the damage as much as possible:
- Use self-adhesive anti-tip straps as an alternative to screws. They have a small adhesive surface and are easier to remove.
- Use furniture brackets or tension rods that can be adjusted between the floor and ceiling (if height-adjustable) without damaging the wall.
- Also be careful not to damage the floor, as furniture without wall anchoring tends to slide more easily.
If you have particularly sensitive wall surfaces (e.g., wallpaper), you can also place small pads under the corners in contact to prevent abrasion and marks.
It is also advisable to ask your landlord for permission before installation or to look for a solution together.
I hope these tips help you! There are several ways to set up furniture safely and carefully.
FeAndreas116 Nov 2022 07:48Hello Timpar,
I’ll break down your question in more detail, as there are several important technical aspects to consider:
First: The Brimnes series furniture usually comes with a back panel and a safety wall bracket, which is typically installed using wall plugs and screws. This is necessary to prevent tipping—especially with tall cabinets.
Second: Without wall mounting, the stability is significantly reduced and the risk of the furniture sliding or tipping increases, for example under load or if pets/children pull on it. This should not be underestimated.
Alternatives to wall mounting, which also require certain conditions:
- Using corner frames that are securely wedged between floor and ceiling (so-called tension rod furniture brackets)
- Positioning the furniture within recesses to provide lateral support
- Placing it on non-slip mats or felt pads to minimize sliding
If wall drilling is unavoidable: It is recommended to use only wall plugs that can be easily removed later, such as cavity wall anchors for drywall or special quick-install wall plugs. When moving out, you should be able to professionally fill and repaint the holes.
Finally, I would like to ask: What type of wall material do you have? This plays a major role in the type of fasteners required. Drywall, concrete, plaster—different wall plugs and approaches are needed for each.
If you like, I can give you some precise recommendations for your specific wall type.
Hello Timpar,
Simply put: Strictly speaking, there is hardly any way to securely fasten Brimnes furniture without drilling into the wall. Otherwise, the furniture is more prone to tipping over.
My advice:
- Use the included safety fittings
- If you don’t want to drill, you can increase the furniture’s weight by placing heavier items (e.g., books) inside
- Check if wall fastenings with adhesive solutions are possible, but these are often less durable
Non-wall-mounted solutions are usually compromises; please do not overlook safety.
My advice:
