ᐅ Is it possible to equip IKEA PLATSA furniture with LED lighting systems?
Created on: 15 Jan 2015 14:07
piminHello everyone,
I am considering equipping my IKEA Platsa furniture with an LED lighting system to integrate a modern and functional illumination. I am particularly interested in whether there are practical ways to install LED strips or individual LED modules so that they are both visually appealing and do not impair the furniture’s functionality or stability. Are there any experiences or recommendations regarding which LED systems are compatible or how to organize the wiring discreetly? It would be especially important to know if the Platsa units provide enough space for LED components and their power supply without requiring significant drilling or modifications. Perhaps there are also ready-made solutions from IKEA or third-party suppliers that work well with Platsa.
I look forward to detailed answers, including technical information, to help me make an informed decision.
pimin schrieb:
I am considering equipping my IKEA PLATSA furniture with an LED lighting system to create a modern and functional lighting solution.Basically, it is possible to equip PLATSA furniture with LED lighting systems, as the design of the modules is relatively open and flexible. The modules usually consist of wooden or wood-based panels with interior spaces that provide enough room to install LED strips under shelves or along side panels.
However, the following points should be considered:
- Power supply: LED systems require a mains connection, so access to a nearby power outlet is important. When routing cables, neat installation is essential since PLATSA furniture does not have pre-made channels for wiring.
- Installation: Most LED strips can be attached using adhesive backing or small clips. Drilling is usually not necessary, but small holes might be needed for custom adjustments.
- Compatibility: IKEA does not offer a dedicated LED system specifically for PLATSA. LED strips from third-party suppliers (e.g., 12V systems with flexible printed circuit boards) are recommended.
Conclusion: Yes, adding LED lighting is feasible, but it requires some DIY effort for installation and wiring planning.
Danabla schrieb:
In principle, it is possible to equip PLATSA furniture with LED lighting systems, as the design of the modules is relatively open and flexible.In addition, I would like to explain how to implement the installation easily, even without professional experience. My tips for LED lighting with PLATSA are:
- Use 12-volt LED strips, as these are a standardized and safe solution.
- The adhesive backing on LED strips allows for quick and clean mounting on any smooth surface.
- For power supply, a plug-in power adapter that plugs into a socket near the furniture is recommended.
- If cables run along the furniture, cable ducts or self-adhesive cable clips help keep everything neat.
- For switches or motion sensors, there are small battery-powered options that do not require a nearby socket and can be easily integrated.
The modularity of PLATSA is definitely an advantage for installing LED lighting without major structural changes. If you have questions about specific connections or selecting LEDs, I’m happy to help.
pimin schrieb:
Are there practical ways to install LED strips or individual LED modules so that they are visually appealing while not impairing the functionality or stability of the furniture?I recently created a small DIY guide exactly for this, which includes some practical tips:
1. Planning: Before installation, determine the exact position of the LED strips – frequently, the back panels under shelves or the upper edges are suitable for indirect lighting.
2. Preparation: Surfaces must be clean, dry, and free of grease so that the adhesive on the LED strips sticks properly.
3. Installation: For PLATSA modules, it is advisable to choose narrow LED strips that fit well into the shelf profile without protruding. There are also aluminum LED profiles that can be glued or mounted to diffuse the light softly.
4. Wiring: Usually, a cable duct is attached along back panels or side walls. If small holes are drilled through furniture parts, it is recommended to deburr them carefully to avoid cable damage.
5. Power supply: A 12V transformer with sufficient capacity is recommended. For added convenience, dimmable power supplies can also be used.
6. Safety: Make sure that no cables are pinched on edges or hanging loosely.
In the end, the lighting should be subtle and flexible, without damaging the furniture.
If you like, I can also provide you with a detailed list of suitable products and suppliers.
Guyju schrieb:
Aluminum LED profiles that can be glued in or surface-mounted to diffuse the light softly.In my opinion, this is the best approach. It prevents harsh light edges and also provides dust protection. Simple, effective, clean.
