Heinrich8827 Dec 2021 14:12Good afternoon dear forum members,
I want to install anchors in a brick wall to mount a TV wall bracket with a maximum load of 40 kg (88 lbs). Unfortunately, I am not sure what type of brick this is or if anchors would be strong enough.
Photos are attached. Maybe someone knows better what to do 🙂
Thank you very much in advance
Heinrich8827 Dec 2021 14:19Thank you for the quick response!
My TV also has a 65-inch diagonal and weighs 33kg (73 lbs) without the stands. When tapping the wall, it definitely does not sound solid. That’s why I’m a bit concerned about this.
Benutzer20027 Dec 2021 14:39That’s no problem at all. The bricks will definitely hold – basement, right?
Most likely, even the anchors from the mounting bracket are sufficient. Otherwise, just head to the hardware store. If you’re “worried,” use Duopower 10x80 anchors with matching hex screws. If something still falls down after that, you might want to consider moving out 😉
Hutchinson12327 Dec 2021 14:43We mounted our TV using heavy-duty external hex head screws from Fischer. You probably could have hung a small car on them. Better to have more strength than you need, in my opinion.
External hex heads are definitely preferable because they can be tightened better than Phillips heads.
