ᐅ Easing the Installation of Ikea METOD Kitchen Cabinets on Uneven Floors
Created on: 17 Mar 2015 09:27
Constant31
Constant31
17 Mar 2015 09:27
I am currently facing the challenge of installing my Ikea METOD kitchen cabinets on a rather uneven floor. The varying heights and minor irregularities make it extremely difficult to align the cabinets precisely and set them up securely.
Are there any proven tips or tricks to make the installation of METOD kitchen cabinets easier on such uneven floors?
I am particularly interested in solutions that allow adjusting the cabinets later without much hassle, without compromising stability or requiring complex substructures.
I look forward to your experiences and advice, especially considering the specific construction of METOD.
Johnathon
17 Mar 2015 10:33
Hello Constant31,
I find your question very interesting because the topic of "Ikea METOD installation on uneven floors" indeed involves some challenges. Here is a step-by-step overview of how I usually approach it:
- First, I always use a very precise spirit level or, even better, a digital inclinometer to measure the floor at several points. This is especially important with METOD cabinets due to their adjustable feet.
- METOD cabinets come standard with height-adjustable legs, which can typically be adjusted by 10-13 cm (4-5 inches). These should, in principle, be the first point of adjustment. It is important to adjust the feet not only at the front but also at the back to ensure the cabinet is stable and level.
- If the unevenness is more significant, it can be helpful to add thin shims or special rubber pads to the feet to bridge small gaps and increase slip resistance at the same time.
- For larger height differences, it may be necessary to work with a thin passive substructure. However, this should be as stable and level as possible, since METOD fronts need to be precisely aligned to avoid gaps.
- Finally, I always recommend carefully connecting the cabinets using a carcass connector system, as is standard with METOD. This distributes the load and significantly increases stability.
I would also be interested to know the exact size of the unevenness and whether the floor is made of wood, tile, or another material. That would allow me to give you further advice.
Feel free to share more details so I can assist you more specifically.
Ryder35
17 Mar 2015 11:02
It is best to first align all the cabinets as accurately as possible using the adjustable feet. If necessary, use small wooden wedges or rubber pads as spacers. This will save you a lot of rework.
parpeo
17 Mar 2015 12:18
Hello Constant31,
I can totally understand the situation, as an uneven base can really complicate the assembly. My advice is, besides adjusting the feet, to make sure to connect the cabinets to each other. This way, they balance out better and are more stable.
I’ve also often seen people use MDF boards as a base, cut precisely to size. This creates a uniform foundation and prevents individual cabinets from tipping.
It’s important to install the countertop only once the base is completely stable. Otherwise, you’ll notice the unevenness much more while working.
If you have any questions about the exact procedure, I’m happy to explain in more detail.
Constant31
17 Mar 2015 13:46
Thank you for your already very helpful responses, especially the tips regarding leveling feet and MDF underlays.
Regarding the floor condition: it is an older screed with depressions of up to 15 mm (0.6 inches) in some areas, and irregular elevations of about 5 mm (0.2 inches) in others. The floor is quite rough and not smoothly finished.
[quote=Johnathon, post: s9p3s8, member: XXX]
I would also be interested to know exactly how large the unevenness is and whether the floor is made of wood, tiles, or another material. That would allow for more specific advice.
I understand that 15 mm (0.6 inches) over a length of 60 cm (24 inches) is quite significant and may require a substructure in the worst case. In combination with height-adjustable feet—which you mentioned first as a way to compensate—I am now wondering if you have tips on how to further stabilize the feet. Especially since I want to avoid wobbly cabinets.
Does anyone know suitable materials or fastening options for the feet to improve their durability and stability on such a rough, uneven floor without having to carry out a complete floor renovation?
LuMarcel43
17 Mar 2015 15:09
To stabilize adjustable feet on rough terrain, two points should be considered: First, the feet alone do not bear the entire load; rather, the entire structure carries the load in combination with the cabinet connections.
[quote=Constant31, post: e6e1o6, member: XXX]
Does anyone know suitable materials or fastening methods for the feet to improve their durability and stability on such rough, uneven ground without having to completely renovate the floor?
Second, it is often overlooked that a slight increase in the contact area under the feet, achieved by firmly glued rubber feet or non-slip felt pads, significantly improves stability and better distributes the pressure on the ground.
However, I am critical of many users who simply place these pads loosely underneath. For load-bearing capacity, these pads must be properly fixed; otherwise, cabinets twist under load.
My suggestion: small metal plates with pre-drilled holes could be used, screwed onto the feet and then resting on suitable spacers on the floor. This provides a stable base where nothing shifts.
This solution requires precise work and time but is definitely worthwhile for larger unevenness.
