ᐅ IKEA MALM Nightstand Sunlight Stains – How to Repair?
Created on: 16 Apr 2022 08:23
Stella-tau
Stella-tau
16 Apr 2022 08:23
I have a Malm nightstand from IKEA that has unfortunately been exposed to strong sunlight for quite some time. This has caused unsightly discoloration and light spots, which I clearly attribute to UV damage. As a result, the surface is no longer uniform, making the piece look quite unattractive.
My question is: What is the best way to repair or touch up these spots without having to completely sand down or repaint the nightstand? Are there any home remedies, special repair kits, or perhaps professional tips that can gently restore my MALM surface? I would like to preserve the original finish as much as possible and avoid complicated methods, if feasible.
Thanks in advance for your experiences and advice!
Thierryzar
16 Apr 2022 09:07
Simply touch up the stains with a furniture marker in a matching color. There are also polishes or waxes specifically designed for light wood surfaces that can effectively mask the stains.
BENBI
16 Apr 2022 11:42
Stella-tau schrieb:
How can these stains be best repaired or retouched without having to completely sand down or repaint the nightstand?
MALM nightstands usually have a veneered surface protected by a clear lacquer, so stains caused by UV exposure tend to alter the color of the veneer.
The recommended approach is to first clean the surface thoroughly with a mild cleaner to remove dust and grease. Afterwards, you can try to make spot repairs using a color-matched wood repair pen or marker. It is important to match the color tone precisely, otherwise the repair will stand out even more.
Alternatively, colored furniture waxes or felt-tip pens work well for smaller areas. For larger areas, very careful sanding with fine-grit sandpaper (400-600 grit) can be attempted, but this carries the risk of removing the lacquer.
A complete resurfacing with clear lacquer is more time-consuming but usually allows for approximate restoration of the original color.
Important: Always test any treatment on an inconspicuous spot first! Also, how exactly is the nightstand positioned? Is it exposed to strong sunlight continuously? Changing its location might help prevent further stains from developing.
dijan
16 Apr 2022 13:59
Thierryzar schrieb:
There are also polishes or waxes specifically for light wood surfaces
Exactly, and a light polishing treatment has already removed small “sunburn” spots on my furniture. Sometimes you don’t always need a full repaint – just gently applying a mild wax over the marks and hoping they fade a little 😉. But definitely, the nightstand shouldn’t stay in direct sunlight like someone sunbathing during siesta, or the furniture will soon have a summer tan too! 🙂
Nofege
17 Apr 2022 07:34
I would like to provide a structured guide that can help treat UV spots on MALM nightstands step by step:
1. First, thoroughly clean the surface. Use a slightly damp microfiber cloth with a mild dish soap to remove dust or grease. Do not use any harsh cleaning agents!
2. Test on a hidden corner whether the stain can be reduced by simply polishing with furniture wax. Sometimes the wax absorbs the color difference and conceals it.
3. If that is not enough, try a wood touch-up marker in a matching color. Apply the marker thinly and blend it with a soft cloth.
4. For larger areas, you can very gently sand the edges of the discoloration using fine sandpaper (grit 400-600), but be careful not to sand through the finish.
5. Finally, apply a UV-resistant furniture polish to help minimize future damage.
Important: Perform multiple tests on an inconspicuous spot between steps 3 and 4 to achieve the best result.
If the stains have deeply penetrated the veneer, a complete refinishing is usually unavoidable.
Stella-tau
17 Apr 2022 12:58
BENBI schrieb:
Important: Always test in an inconspicuous spot before making any changes!
Thanks, that’s a really good tip!
I have some additional information about the location of my bedside table: it was placed for a long time directly next to the window, which receives a lot of afternoon sun (west-facing). Because of this, it’s constantly exposed to UV rays. I am considering whether to change its position.
Are there any special varnishes or sealants that can be applied to the MALM bedside table to better protect it from sunlight if I can’t move it? Is that advisable, and are there any long-term experiences with this?
