ᐅ Ikea Faktum wall cabinet with shallow depth, for example 28 cm (approximately 11 inches)
Created on: 8 Nov 2011 08:13
fotokatzeF
fotokatze8 Nov 2011 08:13Hello IKEA fans,
I need a Faktum cabinet carcass, width 80 cm (31.5 inches), height 70 cm (27.6 inches), but with a smaller depth than the "standard" 37 cm (14.6 inches) as it is usually offered. There used to be a version with 28 cm (11 inches) depth. I have already searched other ranges from living room and bedroom furniture without success.
Otherwise, my only option would be to modify a carcass with a saw, but I would prefer to use a finished product.
Does anyone have a tip from the current IKEA range for me or happen to have such a carcass with a smaller depth available?
Thanks!
fotokatze
Thanks!
fotokatze
fotokatze23 Nov 2011 08:06Hello bergpriv!
Thank you for your effort. Billy was no longer on my radar at all! But unfortunately, it just doesn’t fit! As you already mentioned, it’s too tall!
I have to consider trimming it, but that probably won’t be easy since the connectors are in the frame...
We’ll see. If I manage to finish it, I will report back on how I did it.
Thanks again. Best regards, fotokatze
I have already shortened a cabinet carcass in depth several times myself!
You need a 15mm (5/8 inch) drill bit for the connectors and a circular saw—preferably a track saw—and you can use the cut-off piece as a template. Also, have drill bits for metal and wooden dowels.
It’s a bit tedious but it works. Simply attach the back panel with nails; this way you can see the panel from the side, or you can solve this issue by using a finished side panel.
Regards, bergpriv
Regards, bergpriv
