S_t_e_p_h_a_n4 Jun 2021 19:08Hello,
I have a pool in my basement (currently not heated / covered with a pool cover) and I use a dehumidifier. It consumes 2 kWh (2 kWh) in 24 hours.
With the current temperatures here in the north, the window in the pool room is often open and the dehumidifier is turned off.
Why does the humidity not decrease when the windows are open and there is even a draft?
Today, the outdoor humidity is 30% and the humidity in the pool room has risen from 60% to 77%.
The temperatures inside and outside are the same.
Can anyone help me with this?
Good luck,
S_t_e_p_h_a_n
Good luck,
S_t_e_p_h_a_n
S_t_e_p_h_a_n schrieb:
Why doesn't the humidity level drop when the windows are open and there is even a draft?Because more moisture evaporates than can be ventilated out, even with a draft. The only solution is mechanical ventilation.Similar topics
