ᐅ How to position the house on the plot?
Created on: 15 May 2021 13:36
cyberosti
cyberosti
15 May 2021 13:36
We are currently planning the orientation of our house on the property. The house has external dimensions of 12 x 8.25 m (39.4 x 27.1 ft). Our plot is a total of 1304 m² (14,040 ft²) and at the front area, where the house is to be placed, it is about 20 m (66 ft) wide and between 60-64 m (197-210 ft) long overall.
The attached images are already aligned with true north. Access to the property is from the east side. Through the adjoining dead-end road to the south, we have the optional possibility in the future to subdivide the rear part of the property and access it via this road.
Essentially, our question is: How would you position the house on the plot? With the gable end facing the street? This would have the advantage of still leaving a usable garden or terrace area on the south side of the property. If we rotate the house 90 degrees, we would have a great west-facing view into the large garden, also visible from the dormer on the upper floor. Furthermore, if the property is subdivided in the future, the house would probably be better positioned on the smaller plot that would result. A west-facing terrace is actually our preferred orientation.
Please don’t be confused by the two carports. I am not basing the house placement on their locations.
How would you position the house? Am I overlooking anything?
Thanks in advance!
Lageplan eines Grundstücks mit grünem Garten, Haus und Holzterrassen aus Vogelperspektive.
Gartenplan: grüne Rasenfläche, graues Gebäude, zwei Holzterrassen, grauer Pflasterweg.
haydee
15 May 2021 15:40
West garden, also right picture.
Carport not as shown.
cyberosti
15 May 2021 17:58
haydee schrieb:
West garden, so the right picture.
Thank you for your opinion. Why would you do it that way? I am still undecided about the carport as well. Basically, I want to position it perpendicular in front of the house. However, I am still unsure whether to place it on the north or south side...
hanghaus2000
15 May 2021 20:06
If you want privacy from the street, I would place the carport more towards the south.
I like the sun, so for me the left picture is better. It’s also more energy efficient if you have many windows on the south side.
Additionally, the distance to the house located to the south is greater, if there is one. Unfortunately, you didn’t provide enough information on that.
cyberosti
15 May 2021 20:28
hanghaus2000 schrieb:
If you want privacy from the street, I would suggest placing the carport on the south side.
I like the sun, so for me, the left picture is better. It’s also more energy efficient to have many windows on the south side.
Additionally, the distance to the house located to the south is greater, if there is one. Unfortunately, you didn’t provide enough information.
No, there isn’t one. There is a dead-end lane. A bungalow is located further behind it.
11ant15 May 2021 20:37
cyberosti schrieb:
We are currently planning the orientation of our house on the plot. The house has external dimensions of 12 x 8.25 m (39.4 x 27.1 ft).
That sounds like a specific house model – which probably also has a defined layout (and rooms for which the placement of their window sides matters).
cyberosti schrieb:
Our plot is a total of 1304 sqm (14,041 sq ft) in size.
... which, to me, suggests a low likelihood of being able to ignore the factor of elevation differences.
Based on this limited information, my answer can at best be "42" ;-)
