ᐅ How durable are Malm furniture pieces under load?
Created on: 29 Dec 2018 18:43
raimond48
I would like to start a discussion on the topic, “How safe are Malm furniture pieces under load?” Especially regarding Malm furniture from IKEA, which is very popular, I am curious about how well these items actually withstand mechanical stress. Specifically, I am interested in how safe they are when, for example, a heavy weight is placed on dressers or drawers, whether the construction remains stable over time, and if there are any known weak points that can appear under heavy loads.
I’m looking for as objective an assessment as possible – including comments on materials, construction, joints, and typical loading conditions. Does anyone have experience with the safety and durability, especially regarding loads beyond normal daily use?
I look forward to your opinions and answers.
raimond48
30 Dec 2018 10:27
pauPierce schrieb:
Are you aware of specific load scenarios that interest you?
Good question! In my case, it mainly concerns using it as a bedroom dresser, which should also serve as a surface for occasionally heavy items – for example, a heavy stereo system (about 15 to 20 kg) and some decorative objects. Additionally, I need drawers that can hold well-filled clothing boxes, possibly with more weight than usual.
I am also considering whether the piece of furniture can be sufficiently stabilized by adding wall mounting in case of point loads. What maximum total load would you estimate the dresser can safely handle without posing a safety risk?
Bautau
30 Dec 2018 12:55
raimond48 schrieb:
estimate maximum total load without safety risk
The maximum allowable load for a Malm dresser model can be determined more reliably from the IKEA manual or its technical data than by estimation. When available, these specify maximum static loads for the top surface (typically around 50 kg (110 lbs)) and for the drawers (usually about 15 kg (33 lbs)).
Load capacity mainly depends on the construction, the thickness of the particleboard, the quality of the fasteners (dowels, biscuits, screws), and the drawer slides (metal runners with ball bearings).
For your use, with a stereo system weighing 15 to 20 kg (33 to 44 lbs) on the surface, caution is advised: the dresser might support this load if it is evenly distributed, but not permanently without deformation. Therefore, wall mounting is strongly recommended to minimize tipping and stability risks.
Regarding the drawers, the weight per drawer should not significantly exceed 15 kg (33 lbs). Even distribution of the load in the drawers helps avoid point overload. In addition, proper assembly and regular inspection of the fasteners are important.
In conclusion, I believe that a combination of wall mounting, observing load limits, and careful use provides sufficient safety for the intended application you described.
NOAHSAU
30 Dec 2018 14:38
raimond48 schrieb:
how durable are Malm furniture pieces under load?
Sometimes I wonder if all these IKEA furniture pieces are somewhat overrated. Sure, they are affordable and look good, but honestly, I don’t have much confidence in their long-term stability under heavier loads. Particleboard just isn’t the strongest material – and especially with Malm, which emphasizes modern design, stability might be compromised.
I’m not saying the furniture will fall apart right away, but if someone puts a lot of weight on a Malm dresser or sits on it, they should be aware that it’s at their own risk. Solid wood furniture might be a better choice in this case.
A bit provocatively: Has anyone here ever been truly satisfied after intentionally pushing the weight limits? Or is Malm mainly about aesthetics and price?
