ᐅ How do you properly attach an IKEA PAX back panel?
Created on: 2 Feb 2021 08:24
Meobengt
Meobengt
2 Feb 2021 08:24
Hello everyone, I recently assembled an IKEA Pax wardrobe and have now reached the back panel. I am interested in how to best and, above all, correctly fasten the back panel to ensure it stays stable and the wardrobe maintains its shape. Specifically: Should the back panel be attached only with the small nails provided, or are there better methods? I am also wondering if special care should be taken when hammering in the nails to avoid warping or damaging the back panel. Are there any tips regarding the positioning of the nails or screws, if these are used? I want to prevent the back panel from coming loose later or the wardrobe becoming unstable. I would appreciate any experiences and instructions.
FLOBAU
2 Feb 2021 10:06
The correct attachment of the back panel on an IKEA PAX wardrobe is usually done using the small nails provided for this purpose. It is important to place these nails evenly along the frame to ensure uniform tension on the back panel. This helps prevent the panel from warping.
It is advisable to align the back panel precisely before nailing and, if possible, temporarily secure it with clamps or small clips to prevent shifting during installation.
When hammering in the nails, use a hammer with a small head and work carefully to avoid dents or cracks in the thin back panel. Drilling holes and fastening the panel with thin screws is generally not recommended, as the panel is often made of thin particleboard and can easily split.
Additionally, the nails provide the necessary flexibility for material expansion, which is not always the case with screws.
GUSTAVO56
3 Feb 2021 13:17
FLOBAU schrieb:
It is advisable to accurately align the back panel before nailing and, if possible, temporarily secure it with clamps or small clips to prevent shifting during assembly.
This is a very important point that is often underestimated. I recommend the following procedure when attaching the PAX back panel:
- Position the back panel in place and hold it firmly with light pressure (e.g., by hand)
- Temporarily secure it with small, thin nails or clips at key points before nailing to prevent slipping
- Make sure the back panel lies completely flat without sagging or protruding
- When nailing permanently, use a rubber mallet (or a hammer with a soft striking surface) to avoid damage
- Space the nails approximately 10-15 cm (4-6 inches) apart along the edges for optimal stability
Note: If the back panel does not fit well or already shows any warping, nailing later on can cause deformations. Therefore, I also recommend checking the back panel on a flat surface before installation.
How have you fixed the back panel so far? Is it already installed or are you still at the beginning?
Meobengt
3 Feb 2021 15:02
GUSTAVO56 schrieb:
How have you attached the back panel so far? Is it already installed, or are you still at the beginning?
Thank you for the detailed tips! I haven’t attached the back panel yet because I was unsure about using a hammer. I wanted to avoid breaking the panel or having it warp when hammering in the nails, since the material feels thin and quite delicate. Besides the nails provided, I also have small screws and a screwdriver, if that makes any sense—but your warning about the panel splitting almost makes me want to forget about that idea.
Do you or anyone else have experience stabilizing the back panel before nailing it in without special tools? Or is it best to prepare the back panel lying flat on the floor? I imagine it’s difficult to hold the back panel in place on the cabinet without it slipping.
kemads46
4 Feb 2021 09:41
Meobengt schrieb:
Do you or anyone else perhaps have experience with how to securely position the back panel before nailing it, without special tools? Or is it best to prepare the back panel lying flat on the floor?
My recommendation: You can indeed lay the back panel on a clean, flat floor and align it first. This way, you can check if it is flat and has no warped edges. After that, carefully slide the cabinet over it or place the cabinet onto the back panel so it fits exactly along the edges.
Practically, it helps to have a second person hold the back panel in place while you drive in the nails. If that is not possible, you can also use tape to temporarily fix the back panel to the frame. The tape acts as a holder to prevent slipping.
General tips:
- Use a hammer with a small striking surface or a rubber mallet
- Do not drive the nails in too deep; they should be just recessed without damaging the material
- If you plan to remove the back panel again, it is advisable not to drive the nails all the way through
- Avoid screws, as these often cause the material to split
Summary: Preparation on the floor + fixing with tape or helper + careful nailing = stable and damage-free back panel installation.
