ᐅ How can you prevent Ikea Pax doors from rattling when closing?
Created on: 23 Nov 2020 08:42
Efetau55Hello everyone, I have been using the Ikea Pax wardrobe with the typical hinged doors for some time now and have encountered a recurring problem: when closing the doors, there is often a rattling noise that concerns me because it is quite loud and annoying. I have already considered the possibility of loose hinges or misaligned doors, but it doesn’t seem to be caused by that alone.
I would like to know if you are aware of any specific measures or tips to prevent this rattling when closing the doors. Are there particular adjustment options on the hinges that should be considered? Or do certain dampers or pads help? Maybe there is a professional trick that Ikea doesn’t reveal directly.
Thanks for your advice – I am somewhat technically inclined but want to solve the problem as cleanly and permanently as possible, without just softening the doors in some way.
Hey Efetau55, great question! 😊 That kind of rattling can be really annoying, but I have a few tips that should help you!
First: Check if the doors are properly adjusted! Ikea PAX hinges have adjustment screws on three axes – up-down, left-right, and front-back. If the door doesn’t sit flush, it can easily cause rattling.
Second: I applied small foam or felt pads where the door meets the cabinet frame. This absorbs the noise really well without needing to change any of the hardware!
Third: If you like, there are special soft-close dampers you can retrofit that gently slow the door closing. That really takes the annoyance away!
Give these a try and let us know how it goes! Good luck!
Hello Efetau55,
I am familiar with this issue and have looked into it more thoroughly because the rattling is not only annoying but can also be caused by material fatigue. Here are a few tips I can recommend from a technical perspective:
- First of all, definitely check whether the doors close flush and without any tension. This is especially important with PAX, as the frame can easily warp. Use a spirit level or a feeler gauge to check the accuracy of the fit.
- The hinges on Ikea PAX units are standardized and have three adjustment axes. The fine adjustment of the screw that presses the door against the cabinet front is crucial – too much gap causes rattling.
- If the hinges themselves seem unusually loose, they might need to be replaced. Usually, tightening the screws slightly helps.
- For damping, you can apply special self-adhesive silicone or rubber buffers to the door frame. These prevent metal-to-wood impacts.
- Additionally, small but high-quality soft-close mechanisms that Ikea offers can be retrofitted. These are often easier to install than one might think.
One question for you: Have you ever completely removed the hinges and checked whether they have any play or are worn out? This could be a cause of the rattling.
I hope this helps! A careful analysis is worth the effort; otherwise, the frustration can last a long time.
Efetau55 schrieb:
I would like to know which specific measures or tricks you know to prevent rattling when closing. Hello Efetau55,
Your question is very precise, which makes it easier to provide advice!
To avoid rattling from the Ikea PAX doors, I recommend a combination of the following steps:
- Adjust the hinges using an Allen key: Pay attention to the gap between the door and the cabinet frame. Too much space is often the cause of rattling noises.
- Check that the mounting screws are tight.
- Add soft buffers, such as felt pads or small rubber pads, at the contact points of the doors.
- If needed, you can retrofit soft-close adaptors, which make closing much smoother and quieter.
This combination usually reduces rattling noises effectively and sustainably. It’s worthwhile to proceed step by step and test the effect. If you want, I can provide more details on individual components.
Good luck with optimizing!
From my experience with Ikea PAX, a structured approach is helpful. It is important to first precisely check the door alignment. Carefully adjust the three screws per hinge as follows:
- The height adjustment corrects the vertical alignment of the door.
- The depth adjustment ensures the doors sit flush with the cabinet frame.
- The lateral adjustment influences the gap between the doors.
Often, an inaccurately set lateral gap causes the doors to rub against each other or the cabinet frame when closing, which can result in rattling.
For those who want to further reduce noise, self-adhesive felt pads should be applied not only at hinge contact points but also at the ends of the doors.
Note: Excessive readjustment can compromise the door stability. Check the hinges for damage or wear. Faulty hinges can cause play and should be replaced.
If soft-close dampers are desired, I recommend the Ikea-specific soft-close system designed for PAX, which is easy to integrate.
