ᐅ What is the best way to secure Ikea Pax wardrobes to wooden floors?
Created on: 28 Mar 2020 16:37
Nukla40Hello everyone,
I recently bought an Ikea Pax wardrobe and now want to secure it to my wooden floor. Since the floor isn’t completely level and the wardrobe will be quite large and heavy, I’m concerned about stability and protecting the floor.
My question is: What is the best way to fix an Ikea Pax to wooden floors so that the wardrobe stands securely, does not damage the hardwood flooring, and can also be removed later without leaving any marks if needed? Are there any specific techniques, materials, or accessories that are especially recommended?
Thanks for your expert advice!
Hello Nukla40,
your question about fastening Ikea Pax wardrobes on wooden floors is very relevant, especially since wood floors can be sensitive to pressure and moisture. I will summarize the basics on how to proceed here.
- First: Level alignment is important. Wardrobes like Pax should not wobble. Use small furniture glides with felt pads or special height-adjustable screws if the floor is uneven.
- Second: For the actual fastening, there are several options. The Ikea Pax modules have pre-drilled holes for attaching them to the wall. However, I would not recommend driving screws directly into the wooden floor to avoid damaging it.
- Third: To improve stability, you can place anti-slip mats or special rubber adhesive strips under the feet. These prevent the wardrobe from sliding and also protect against scratches.
- Fourth: If fastening is absolutely necessary, I recommend using a mounting sealant or fabric tape before screwing directly into the floor. Alternatively, there are brackets on the rear of the wardrobe that fasten mostly to the wall rather than the floor.
In summary:
- Never screw directly into wooden floors without protection
- Use felt glides and anti-slip mats
- Ideally, fasten to the wall, not the floor
If you want a solution that leaves no residue, felt glides combined with anti-slip mats are the best option. If you have questions about wall mounting, feel free to ask.
Yes, special furniture glides with felt and anti-slip pads are often underestimated but very helpful.
In summary:
Nukla40 schrieb:
Are there any special techniques, materials, or accessories that are particularly recommended?
To add to the already helpful advice, I would like to recommend the following:
Wooden floors are very sensitive to point loads, especially with heavy furniture like Pax wardrobes. Therefore, I would avoid using screws or nails to fix furniture to the floor, as this can cause permanent damage to the surface.
It is important that you:
- Use felt pads or furniture feet with a sufficiently large contact area to distribute the pressure on the floor.
- Use rubber anti-slip mats to prevent lateral slipping. These are also ideal for avoiding moisture damage because they create a small air layer.
Furthermore, the wardrobe should definitely be secured to the wall. Ikea provides suitable brackets for this purpose. Wall mounting ensures stability much better than any floor attachment.
Another tip: Always use gliding or protective material under furniture on genuine wooden floors, as otherwise, movement can cause scratches or dents on the surface.
This is absolutely correct. Any direct screwing into wooden floors carries significant risks for the flooring.
If the wardrobe still stands on very smooth parquet flooring and you consider floor fixing essential, there are special floor anchors with protective covers. However, these are rarely recommended and are not specific to Ikea.
fugolo schrieb:
Never screw directly into the wooden floor without protection
flo-Theres30 Mar 2020 08:02I agree with the previous comments and would like to add another point.
For wooden floors, especially parquet or laminate, it is important not only to securely fix the wardrobe but also to ensure air circulation underneath the furniture to minimize moisture damage.
In some cases, using small spacers made of plastic or rubber under the furniture feet can be helpful, slightly elevating the piece. This prevents direct contact with the floor surface and reduces the risk of trapped moisture or condensation. This is particularly relevant when doors and windows nearby are frequently opened, causing fluctuations in humidity.
If you are attaching the wardrobe to the wall anyway, usually using felt pads and anti-slip pads under the feet is sufficient to protect the floor.
I want to emphasize this: wall mounting is absolutely essential for the safety and stability of the Pax wardrobe series, especially if there are children in the household or if the wardrobe will be heavily loaded.
KAMERON schrieb:
Wall mounting provides much better stability than any floor anchoring.
