ᐅ How can IKEA BRIMNES furniture be assembled to allow for easy disassembly?
Created on: 3 Dec 2021 08:37
ellupeo
ellupeo
3 Dec 2021 08:37
I am currently considering how to assemble IKEA Brimnes furniture in a way that allows it to be disassembled later as easily as possible and without damage.
Specifically, I am interested in which assembly techniques, fasteners, and assembly steps are recommended to make the disassembly process straightforward. I am thinking about the use of screws, dowels, connectors such as wooden joints, and whether, for example, pre-drilled holes or certain types of screws offer better options for disassembly.
It would also be helpful to know if it is advisable to use the original tools for assembly, or if alternative tools or different methods might make later disassembly easier.
Does anyone have experience with how to build or assemble BRIMNES furniture in a way that prevents damage during disassembly and allows the parts to be reused without any issues?
jaanda
3 Dec 2021 10:04
Basically, it is important to use the original fittings and screws included with BRIMNES furniture, as these are designed to match the material thickness and connection types.
For an easy-to-disassemble assembly, I recommend:
- Never tightening screws too much, as engineered wood can be damaged.
- Loosening all fasteners loosely during assembly first, then tightening them finally to avoid stress.
- If possible, using screws instead of wood glue and nails, as screws can be removed again.
- Inserting small parts like dowels carefully, since they often break when disassembling.
Additionally, it can be helpful to document the rotation direction and position of each screw to disassemble it more efficiently.
You should rely on pre-drilled holes, since making your own changes can impair stability and make disassembly more difficult.
LENNAU
3 Dec 2021 11:22
In addition to the points mentioned:
Another tip is to handle the supplied assembly hardware carefully and avoid damaging the screws. I personally use a cordless drill with a torque setting to prevent over-tightening the screws and thus protect the threads in the wood.
jaanda schrieb:
- Never tighten screws too much, as engineered wood products can be damaged.
This really helped me avoid screws becoming impossible to remove during later disassembly.
If you approach the assembly in an organized way, by first loosely inserting all screws in one part and only tightening them at the end, you can prevent warping that would make disassembly more difficult.
Another recommendation: Keep screws in small, labeled containers in case you lose them during disassembly. This makes reassembly easier.
I also find that BRIMNES, with its flat panels, is generally quite easy to take apart as long as the connections are not glued or the original construction method is not modified.
If someone needs to move the furniture frequently, I recommend not fully tightening all screws but leaving them moderately tight.
theo63
4 Dec 2021 09:51
Interesting approach to examining the origin of the question:
Why is it that IKEA BRIMNES furniture is sometimes difficult to disassemble?
I suspect that the material quality and IKEA’s common assembly method, which includes wooden dowels and screwed-in metal connectors, is a compromise between price, stability, and ease of assembly. This often results in parts becoming twisted or wood damage occurring during disassembly if not handled carefully.
ellupeo schrieb:
I am particularly interested in which assembly techniques, fasteners, and steps are recommended to make the disassembly process straightforward.
I wonder if it would be technically feasible to introduce a system using connectors designed for modular furniture, such as dovetail joints or cam-lock fasteners, which are easier to undo.
Are there known methods to adapt the existing BRIMNES system for easier disassembly or to improve the construction during assembly so that disassembly can be done without damage?
Also: How often have you disassembled the furniture? Is the extra effort worthwhile during initial assembly if you only take it apart and reassemble once?
