ᐅ How can I safely use BILLY shelves in the bathroom?
Created on: 16 Aug 2024 08:37
TEOREO
TEOREO
16 Aug 2024 08:37
Hello everyone, I am planning to use a BILLY shelving unit from IKEA in my bathroom, but I am unsure how to safely mount and use it so that it is not damaged by moisture and typical bathroom conditions, or even toppled over. Specifically, I am interested in recommended mounting methods, whether a special coating or treatment of the material is advisable, and if there are any particular considerations for placing it in the bathroom (e.g., distance from the shower, securing it to walls, etc.). Does anyone have experience or concrete tips on how to safely and permanently use the BILLY shelving unit in the bathroom without problems like mold, rot, or instability?
neoren
16 Aug 2024 09:44
BILLY shelves are not specifically designed for high humidity. It is important to secure the shelf to the wall and maintain a distance from the shower. It is best to treat it with water-resistant paint or protective film.
Palenar
16 Aug 2024 11:12
Hello, first of all, it is important to understand the material itself. The BILLY shelves are mainly made of particleboard with a melamine resin coating. While this coating is durable, it is not completely waterproof. Bathrooms often have high humidity and splashing water, which can cause swelling and damage over time.
Therefore, the following is recommended:
1. An additional treatment with moisture-hardening lacquer or at least sealing the edges, as moisture tends to penetrate there.
2. Always mount the shelf on sturdy wall sections – preferably using anchors for solid walls or sufficiently strong masonry anchors.
3. Install the shelf at least 30 cm (12 inches) away from the shower or sink to avoid water splashes.
Ventilation is also important: a bathroom with regular ventilation or an exhaust fan reduces the risk of mold forming under and behind the shelf.
Do you have a radiator or a fan in your bathroom? This also affects moisture levels.
TEOREO
16 Aug 2024 11:47
Palenar schrieb:
Do you have radiators or a fan in your bathroom?
Yes, the bathroom has a wall-mounted radiator and a small exhaust fan. Ventilation is reasonably good, although there are no windows directly in the room.
Thank you for the tips on sealing the edges. Does anyone know if IKEA recommends its own protective coatings, or if an alternative, specialized lacquer would be better? Also, I would be interested to know the best way to mount shelves on tiles without damaging them.
Lorukeo
16 Aug 2024 13:25
For sealing BILLY shelves in the bathroom, I recommend applying a thin layer of high-quality, waterproof clear varnish based on PU or acrylic. These varnishes provide better protection than the original melamine coating. To my knowledge, IKEA does not offer a specific protective varnish for BILLY shelves.
For mounting on tile: use a tile drill bit with a small diameter and special wall plugs to avoid cracking the tiles. A hammer drill is usually not necessary; a regular drill with low RPM is sufficient. Be sure to use a drill guide before drilling to prevent slipping. Afterwards, you can securely fasten the shelf with strong wall plugs.
KLO-KA
16 Aug 2024 14:05
It is also important not to overload the shelves, as BILLY shelves are designed for light loads. In the bathroom, it is better to store cosmetics and towels instead of heavy containers. Wall mounting prevents tipping.
