ᐅ How can I safely use BILLY shelves in the bathroom?
Created on: 16 Aug 2024 08:37
TEOREO
Hello everyone, I am planning to use a BILLY shelving unit from IKEA in my bathroom, but I am unsure how to safely mount and use it so that it is not damaged by moisture and typical bathroom conditions, or even toppled over. Specifically, I am interested in recommended mounting methods, whether a special coating or treatment of the material is advisable, and if there are any particular considerations for placing it in the bathroom (e.g., distance from the shower, securing it to walls, etc.). Does anyone have experience or concrete tips on how to safely and permanently use the BILLY shelving unit in the bathroom without problems like mold, rot, or instability?
GALEO4
17 Aug 2024 09:56
neoren schrieb:
It’s best to treat it with water-repellent paint or foil.
Foil?! To me, that sounds more like a temporary fix and doesn't look very appealing either. If you use BILLY in the bathroom and need to go to such lengths, you might as well get a shelf made of a more water-resistant material. Why settle for half measures?
Besides, anyone who thinks they can just “keep distance from the shower” should take a look at how small many bathrooms are. In my experience, that is often simply not realistic.
ju_ren
17 Aug 2024 11:47
The BILLY shelf is generally only somewhat suitable for use in bathrooms. However, with proper installation (wall mounting), ventilation, and sealing of cut edges, it can work. It is important to prevent significant moisture buildup and to check it regularly.
tra_nina
18 Aug 2024 07:31
In summary:
- BILLY shelves should be fixed to the wall, ideally using appropriate anchors suitable for the wall type.
- Treat edges with a waterproof clear varnish to prevent capillary action.
- Maintain a distance of at least 30 cm (12 inches) from wet areas.
- Ensure good ventilation in the bathroom to reduce condensation.
- Avoid heavy objects, as the shelf is not designed for high loads.
This allows for use in the bathroom with an acceptable level of risk.
