ᐅ How can I reinforce Malm drawers?
Created on: 14 Feb 2023 08:37
atillaja
atillaja
14 Feb 2023 08:37
I have a problem with the drawers of my Malm dresser set from IKEA. The drawers sometimes stick or don’t slide smoothly anymore, which is probably due to the mechanism or alignment. It is important to me to improve the stability of the drawers without completely replacing the original parts.
Does anyone have experience or tips on how to make the Malm drawers more stable long-term? For example, maybe a simple adjustment of the rails, tightening the screws, or are there any known reinforcement methods that are not too complicated?
Best regards!
LUISABEL
14 Feb 2023 10:52
Hello atillaja,
To stabilize MALM drawers, I recommend first checking and adjusting the drawer slides. It is crucial that the rails are mounted exactly parallel and securely to the dresser, otherwise the drawer may stick or wobble.
Additionally, it often helps to inspect the plastic runners at the ends of the drawers and replace them if needed, as these wear parts improve the drawer’s guidance.
Another step is to slightly tighten the screws on the drawer front to keep it stable. If the drawer has side play, small felt or foam strips on the inside edges of the sides can help achieve a tighter fit.
Overall, these measures are common ways to enhance stability without having to replace whole parts. I hope this helps you.
LEEJU
14 Feb 2023 11:14
Exactly, check the screws on the rails; tightening them is often enough. Sometimes it also helps to completely remove the drawer and clean the rails.
Occasionally, lightly lubricate the sliding rails if the plastic components allow it.
CARLA
15 Feb 2023 09:26
atillaja schrieb:
Improving drawer stability without completely replacing the original parts
One effective approach is to add small metal brackets inside the drawer sides in addition to the original slides, which stiffen the sidewalls. This reduces lateral play and makes the drawer operate more smoothly.
LEEJU schrieb:
Cleaning and lubricating the slides
Be careful when lubricating: please use only silicone-based lubricants to avoid damaging any plastic components. This extends the lifespan of the drawer slides.
With my MALM dressers, it has also proven useful to occasionally check the running tracks for loose back panels or warped wooden strips. Deformations like these can otherwise worsen issues.
For older models, please also inspect whether the runners are still fully intact or if there are small cracks; in such cases, replacing the affected parts through IKEA can be helpful.
