ᐅ How do I securely mount Ikea Metod cabinets to walls made of different materials?
Created on: 25 Jun 2020 09:17
ninago
ninago
25 Jun 2020 09:17
Hello everyone, I am currently planning to install Ikea Metod kitchen cabinets on my wall. The challenge is that the wall consists of different materials: brick in the lower section, drywall above that, and some areas with wooden beams behind the drywall. My question is: How can I securely mount the Metod cabinets on such a mixed-material wall to ensure everything is stable and long-lasting? Which fasteners should I use to accommodate the different wall materials? Are there any special installation steps or tips when dealing with a wall made of a combination of masonry, drywall, and wood? I want to make sure nothing gives way under the load of the cabinets later on, and that the wall won’t be damaged. Thanks for your advice and experience!
glamo
25 Jun 2020 10:42
Hello ninago, that is a very good and precise question – the topic definitely deserves a detailed answer. Basically, when installing the Ikea Metod cabinets on a heterogeneous wall with different materials, you need to use various fastening solutions to safely distribute the load.
- For the brick wall, heavy-duty anchors approved for masonry should be used. The anchors must have the required load capacity and be screwed in deep enough. Note that cavity anchors are not suitable for hanging heavy kitchen cabinets.
- For the drywall (plasterboard) over the brick, it is crucial to check whether there are supporting beams or a substructure behind it. Drywall alone cannot carry such loads. Always screw the cabinets, if possible, directly into the wooden beams, i.e., the load-bearing substructure, and not just into the drywall panels.
- If the beams are not in the optimal position, you can fix a wooden battens substructure (counter battens) to the wall, onto which the cabinets are then screwed. These battens also need to be securely anchored, for example with heavy-duty anchors in the brick.
- For the drywall area, reinforced drywall anchors (e.g., metal clip anchors) can also be used if no direct beams are found, but this is a rare solution and not the safest option for heavy Metod cabinets.
- Make sure not to exceed the recommended load values for screws and anchors with your specific wall material. Also, measure the panel thickness and the distance between the beams accurately.
- An important tip: before installation, use a depth drill bit or an endoscope to examine the exact structure behind the drywall. This helps avoid incorrect drilling and ensures you reliably hit the wooden beams.
- Include the mounting frames of the Metod cabinets in your planning, as they distribute the pressure over several points.
I’m also interested in details like the planned cabinet size and whether you want to install individual units or combinations, as this can affect the choice of fastening methods.
If you like, feel free to share more about the dimensions and the exact wall structure, so I can help you more specifically.
Bagupo
26 Jun 2020 08:03
glamo schrieb:
- For the brick wall, heavy-duty anchors approved for masonry should be used. The anchors must have sufficient load capacity and be installed deep enough.
That is correct. For brick walls, always use metal expansion anchors or chemical anchors.
glamo schrieb:
- For the drywall panels over the brick, it is crucial to check whether there are supporting studs or a substructure behind them.
Exactly, drywall alone cannot hold cabinets without studs. If studs are present, screw directly into them. If not, a counter battens framework should be installed.
glamo schrieb:
- Also use reinforced drywall anchors (e.g., metal clip anchors) specially designed for drywall areas if no direct studs are found.
Metal clip anchors are the minimum option if no wooden studs are present, but they are suitable only for light loads.
Gregory
27 Jun 2020 14:39
Additionally and as a summary of the previous posts:
- When combining brick walls, drywall, and wooden beams, it is advisable to transfer loads as directly as possible onto the supporting substrate – that is, brick or wood.
- Proper installation means aligning the mounting points of the Metod cabinets exactly with the wooden studs behind the drywall. A high-quality professional stud finder helps to locate them reliably.
- For the brick sections, use high-quality heavy-duty anchors with a large diameter to ensure sufficient load capacity.
- If in doubt, installing a counter battens framework (40x60 mm (1.6x2.4 inches) or similar) along the wall is recommended. This wooden substructure is securely screwed into the solid masonry points and creates a continuous mounting surface.
- The Ikea Metod cabinets are then mounted to this substructure using suitable wood screws (at least 5x70 mm (0.2x2.8 inches)).
- At all fastening points, pay attention to maintaining the recommended minimum spacing of the anchors and ensure that no cables or installations are damaged.
- When combining different fastening materials, consider the load-bearing capacity of each to avoid overloading.
- Finally, I recommend carefully measuring and marking all fastening points before drilling and paying attention to the weight distribution of the finished cabinets.
This way, the wall mounting will be stable, secure, and durable.
