ᐅ How can I securely fix MALM furniture to laminate flooring?
Created on: 28 Oct 2019 10:07
Bartan7
Bartan7
28 Oct 2019 10:07
I’m planning to secure my new Malm furniture pieces to a laminate floor to prevent wobbling and slipping. Since these pieces are often quite tall and sometimes narrow, safety is important to me. I’m particularly interested in how to fasten the furniture in a way that protects the floor while still being stable, without damaging the laminate.
What are the best methods to securely fix Malm furniture to laminate flooring? Are there specific fixing systems or tips I should consider? Experiences with anchors or clamp devices would also be helpful.
Thanks in advance for your advice and suggestions!
KIN42
28 Oct 2019 11:33
Hello Bartan7,
Regarding your question about how to securely fix MALM furniture to laminate flooring, there are a few practical options. Since laminate can be easily damaged by screws or anchors, I strongly advise against drilling directly into the floor.
A safe alternative is to use non-slip pads or rubber bumpers under the furniture to prevent it from moving. These are easy to install and leave no marks. Additionally, you can secure the furniture to the wall – IKEA often provides suitable wall anchors that can be fixed to the wall with wall plugs, avoiding any impact on the floor.
For wall mounting, you will need appropriate wall plugs depending on your wall type, and it is important to install the bracket in a way that prevents the furniture from tipping over. A tip: check if the MALM furniture comes with compatible safety straps or metal brackets. If not, universal wall security kits are available at hardware stores.
This way you avoid damage to the laminate and ensure stability.
marcosku52
28 Oct 2019 12:58
Hi Bartan7 🙂
I have MALM cabinets myself and can say: it’s best to avoid “sliding” them directly on the laminate floor. I always use self-adhesive rubber pads—they’re cheap, don’t damage the floor, and provide excellent grip.
KIN42 schrieb:
Anti-slip pads or rubber buffers under the furniture that prevent them from moving
That’s exactly how I do it, plus wall mounting. Mine is very simple, using a small bracket attached to the wall—you wouldn’t believe how much stability that adds.
Tip: If you don’t want to drill large holes in the wall, try heavy-duty adhesive hooks—they’re not as secure as screws, but great for renters who want to keep their painter’s deposit in mind 😉
Good luck, and remember: when assembling, always double-check that everything holds firmly—safety first.
pikin
29 Oct 2019 09:45
Additional information:
Directly screwing into laminate or the underlying screed is risky and can cause damage. The safest method is to secure the furniture to the wall using original IKEA mounting hardware or comparable universal safety fasteners.
Additionally, I recommend high-quality anti-slip furniture pads made of felt with rubber edges. These not only reduce movement but also effectively protect the laminate floor from scratches.
If the floor is uneven, small washers or self-adhesive leveling pads should also be used to ensure a stable base.
A systematic step-by-step plan:
1. Assemble the furniture completely
2. Attach anti-slip pads to the feet
3. Secure the furniture with wall brackets
This ensures both stability and floor protection.
marcosku52
29 Oct 2019 17:26
pikin schrieb:
Anti-slip furniture pads made of felt with rubber edges effectively protect laminate flooring from scratches
Absolutely, these are often applied too late unfortunately :-)
One more thing: For MALM drawers, you should keep in mind that the fasteners are not designed for sustained heavy loads. The anti-tip support should therefore be installed not only at the bottom but, if possible, also at the upper part of the furniture piece.
KIN42 schrieb:
Wall fasteners with anchors are crucial for tip-over safety
Exactly. Only for those renting who don’t want to damage the walls, there’s a bit of a dilemma. But usually, a conversation with the landlord helps—safety first!
