ᐅ How do I securely attach Malm furniture to drywall (plasterboard) walls?
Created on: 23 Nov 2021 18:34
Janchen
I am facing the challenge of securely attaching my IKEA Malm furniture, especially dressers and nightstands, to drywall (gypsum board) walls. The walls are old and sometimes double-layered, but I know that drywall alone cannot support the weight. I want to prevent the furniture from tipping over or being pulled out of the wall over time, as I have small children in the household.
My questions:
Which fasteners are especially suitable for drywall to safely mount Malm furniture?
Should I always rely on the wooden or metal studs behind the drywall, or are there suitable anchors that hold well enough?
Are there any specific procedures or tools I should consider when mounting?
I look forward to helpful tips and your experiences. Thanks in advance!
GEKAU51
24 Nov 2021 10:16
What I have to point out repeatedly: When it comes to drywall, the pseudo-planning often ends, and the furniture is installed using "standard anchors."
Jensson schrieb:
Avoid pure plastic expansion anchors, as they usually support only low loads.
That is exactly the crucial point.
I also recommend properly securing the furniture with cavity anchors or metal anchors instead. Alternatively, check the floor fastening – often, you can prevent tipping by securing with brackets at the bottom, which greatly increases safety.
theo63
24 Nov 2021 12:01
I have a question regarding structural load capacity:
How much weight can selected hollow wall anchors with certified load ratings actually support safely?
There are many manufacturer specifications that vary, and often the load capacity is only stated for axial (single-axis) loads. If the furniture is loaded and the load angles change slightly (e.g., a child leaning with force), this could overload the fastener.
Does anyone here have reliable experience or even test reports on metal box anchors or similar anchors for securing furniture to drywall (plasterboard)?
relupa
24 Nov 2021 12:45
theo63 schrieb:
How much weight can selected hollow wall anchors with certified load capacity actually hold safely?
Good question, which also made me uncertain. In the end, I chose a type of anchor that the manufacturer states can hold up to 50 kg (110 lbs). However, I increased the number of fixing points to be on the safe side.
The problem is the dynamic load: short-term stresses and lateral forces are difficult to quantify. Therefore, it’s better to use multiple anchors.
KARJU
25 Nov 2021 07:38
To add to the previous contributions, I would like to point out the following:
The load-bearing capacity of hollow wall anchors depends on several factors:
- Type of drywall (standard vs. fire-resistant boards)
- Material thickness and number of gypsum layers
- Precise installation and drill hole depth
- Direction and type of load (tension, shear)
As preparation, fastening with screws into the substructure can significantly improve stability.
When in doubt, a combination of direct screwing into the studs plus additional anchor fastening is advisable to transfer tipping moments.
For Malm furniture, securing it to the floor with an angle bracket also makes sense – this can reliably prevent tipping and reduce loads.
Jensson
25 Nov 2021 10:08
theo63 schrieb:
Does anyone here have reliable experience or even test reports on metal box anchors or similar anchors for fixing furniture to drywall?
To add: Metal box anchors typically have a load capacity of 40–60 kg (88–132 lbs) each, depending on the manufacturer and drywall thickness. For furniture weighing more than 60 kg (132 lbs), you should use at least two anchors.
Common mistakes include drilling holes that are either too large or too small, preventing the anchor from expanding properly. The compatibility between anchor and screw is also important—use the correct screw matched to the anchor’s load rating.
My advice: use screws and anchors from the same manufacturer and carefully follow the installation instructions.
glapu
25 Nov 2021 13:54
I always use a combination of direct screwing into the stud frame and tilt brackets at the base for Malm furniture.
This provides greater stability against tipping and remains secure even when used around small children.
