ᐅ How can I securely attach BILLY shelves to drywall (plasterboard) walls?
Created on: 2 Jan 2020 08:13
Roenzo
I plan to mount several IKEA Billy bookcases on drywall partitions in my apartment. Since the walls are obviously not solid, I’m concerned about the stability, especially when heavy books or decorative items will be placed on them. My questions are:
1. Which mounting methods and anchors are best suited to securely attach Billy bookcases to drywall?
2. Is it always advisable to install additional reinforcement behind the drywall, such as wooden battens or special backing panels?
3. Is there a maximum load per shelf to consider when the bookcase is mounted on a non-load-bearing wall?
I’m looking forward to your experiences and tips, especially advice on how to avoid common mistakes and ensure the shelves are safe and won’t break off under load.
Thank you in advance!
Nicksin
3 Jan 2020 07:38
Juan31 schrieb:
If access from the inside of the wall is not possible, the battens can alternatively be mounted on the surface of the drywall along with the shelf.
Doesn’t that look a bit unappealing aesthetically? But hey, stability comes before beauty, right? 😉
Regarding anchors for BILLY shelves on drywall with metal studs: I’ve had good experience with metal anchors that expand behind the drywall and grip securely.
It’s important not to put too much weight on a single anchor and to distribute the load evenly. Always use multiple fixing points! This way, the shelf remains stable and your books stay safe.
Genevieve
3 Jan 2020 09:42
I see that different approaches are being discussed here, but I wonder: Is screwing directly into drywall panels on metal stud walls always the best method?
It is often recommended to anchor into the metal studs to securely hold the load. However, the metal profiles are usually only 0.6 to 0.8 mm (0.02 to 0.03 inches) thick. Without special metal anchors, the material can easily become deformed.
Ernesto schrieb:
The types of anchors you use must be specifically matched to the type of wall.
That’s the key point. I would advise everyone to carefully select suitable special anchors for metal studs before installation or, if necessary, to add additional crossbars or reinforcement rails.
It’s also worth considering whether the shelf might be better installed as freestanding or secured to the floor if the wall cannot support sufficient load. Adequate protection against tipping is often more important than maximizing wall load capacity.
What are your thoughts on freestanding solutions?
