ᐅ How can I securely attach Billy shelves to drywall?
Created on: 26 Aug 2023 18:23
Nutoko
Hello everyone, I have a problem where I could really use your help: How can I securely fasten my Billy shelves to drywall?
My issue is that the shelves are quite heavy, and I don’t want to just screw directly into the drywall because that would compromise stability. It’s important to me that the mounting holds long-term and that the shelf remains safe even when fully loaded.
I have already considered special anchors but am unsure which type is best: hollow wall anchors, metal toggle bolts, or is it better to screw directly into the wall studs?
Perhaps someone here has had similar experience or can offer advice on the approach and suitable materials — also how to best prepare the mounting. Thanks in advance!
sarlo
27 Aug 2023 11:33
Nutoko schrieb:
I’m curious about the ideal length of screws to provide sufficient hold in wood or metal studs without damaging the wall or the opposite side.
That’s a good question! For wood studs, I recommend using wood screws at least 5 cm (2 inches) long to ensure a strong hold. It’s important that they aren’t so long that they pass completely through the stud and protrude on the other side.
For metal studs, self-tapping screws between 3.5 and 4.5 cm (1.4 to 1.8 inches) are suitable, as they grip the metal securely. Since metal studs are usually thinner, longer screws don’t make sense.
Nutoko schrieb:
Maybe someone knows a simple way to make sure the chosen wall plug is appropriate for the drywall thickness and the load?
I recommend carefully reading the specifications on the packaging. Manufacturers often list the maximum load capacity per wall plug for drywall and the relevant wall thickness.
If you plan to hang very heavy items, it’s advisable to distribute the weight across multiple wall plugs or screw directly into the studs.
In general: it’s better to use a few extra wall plugs than too few, and regularly check that everything remains secure. Thanks for your thoughtful question – helping like this is a pleasure! 🙂
