ᐅ How do I repair Malm dressers after damage?
Created on: 22 May 2016 09:17
koenraad
Hello everyone, I have an important question regarding the care and repair of Malm dressers, especially when they suffer damage from improper use or minor accidents. I’m particularly interested in how to properly and sustainably repair the most common types of damage—such as surface scratches, loose veneer, or small chips on the edges—without causing unsightly stains or color mismatches later on. Which products, tools, and techniques would you recommend to carry out such repairs as professionally as possible? I have already tried touching up scratches with wax sticks, but the results were only moderate. I would also appreciate tips on surface preparation and aftercare to keep the dresser looking good for as long as possible. Any help would be greatly appreciated!
koenraad
22 May 2016 12:35
maureo schrieb:
Put glue underneath, clamp for 24 hours
What type of clamp would you recommend? Should I use special screw clamps, or is it enough to use a heavy book as weight for a small corner? I don’t have any clamps, so it’s important to know if I really need to buy some.
Also, how thick should the glue be applied? I don’t want it to be squeezed out from under the veneer and remain visible.
benonon
22 May 2016 13:06
koenraad schrieb:
What type of press would you recommend?
In most cases, a heavy book or package is enough as a pressing weight, as long as the surface is flat and the pressure is evenly distributed. Clamps are really only necessary if the veneer lifts at an edge or on a curved area, meaning targeted pressure is needed in specific spots.
Regarding glue application: a very thin layer is sufficient. Too much glue will squeeze out and can damage the veneer or dry with an unattractive finish. It’s best to gently work the glue into the veneer with a small brush or toothpick, then carefully wipe away any excess with a cloth.
chen67
22 May 2016 15:21
Hi koenraad, I really like how clearly you phrased your question – it’s easy to follow your thoughts! 🙂
A little tip from my DIY experience regarding your topic: Sometimes simple things like toothpaste can help with minor scratches – just apply it with a soft cloth using circular motions, let it sit briefly, then gently wipe it off. This slightly lightens the scratches and also smooths the surface a bit.
Of course, this isn’t a professional repair, but it’s very practical and quick for small everyday scuffs. Maybe give it a try before reaching for paint or filler!
difepeo
22 May 2016 17:45
That’s interesting. However, I doubt that toothpaste, with its abrasive components, won’t eventually damage the paint layer or cause the veneer to fade.
Does anyone have long-term experience using toothpaste on wood surfaces? Maybe you should test it only on inconspicuous areas.
chen67
22 May 2016 18:30
difepeo schrieb:
I doubt that toothpaste with its abrasive components won’t eventually damage the lacquer layer
As with everything, the dose makes the poison! Toothpaste on wood is a handy emergency trick—not suitable for large areas or deep damage, but it works well on very fine scratches and small spots and usually leaves no residue if you don’t overdo it 😉 So, it’s not a miracle cure, but somewhere between an everyday helper and a tool.
Pome60
23 May 2016 08:53
Wow, what a great discussion here! Last week, I spontaneously repaired my Malm dresser myself – using wax and the tip Benonon gave – fantastic result!!
I just wanted to say: don’t be afraid, it really works well! 🙂 It’s even fun and gives a great sense of accomplishment!
So: go for it with your Malm and show your furniture some love! 🙂
