ᐅ How do I properly replace MALM drawer runners?
Created on: 10 Mar 2022 10:24
Laujeffr52
Laujeffr52
10 Mar 2022 10:24
I am planning to replace the drawer slides of my Ikea Malm chest of drawers because they have started to stick and the drawers no longer slide smoothly. I am particularly interested in the proper procedure for the replacement: What is the best way to remove the old slides without damaging the furniture structure? Which tools and replacement parts are ideal, and are there any special considerations regarding the screws or brackets that I should be aware of? Additionally, I would like to know how to install the new rails precisely so that the drawers operate smoothly and quietly again. Any advice on potential pitfalls or helpful tips would be greatly appreciated. Thanks in advance!
V
Victor54
10 Mar 2022 11:36
Laujeffr52 schrieb:
What is the best way to remove the old drawer slides without damaging the furniture structure?
This is actually the first critical point. In MALM drawers, the slides are usually just screwed in. I recommend using a cordless screwdriver with the appropriate bit and carefully unscrewing the screws slowly to avoid breaking the material.
Laujeffr52 schrieb:
Which tools and replacement parts are ideal?
For the slides themselves, it’s best to use original replacement parts, as different models often do not have the same mounting points. From a practical standpoint, a ratchet with an extension can be useful if the screw placement is awkward.
Laujeffr52 schrieb:
Are there any special considerations regarding screws or brackets I should be aware of?
Yes, Ikea often uses special flat-head screws in the MALM series to sit flush with the surface. It’s worth replacing these as well if they are damaged or rusty.
Precise installation is crucial so that the drawers don’t stick or run unevenly. It’s best to use a spirit level or a ruler to align the slides exactly.
Luciandi
11 Mar 2022 08:57
I also had problems with the MALM drawer slides and was initially unsure about how to handle them correctly.
For me, it was important not to use too much force, but to carefully remove the old rails and check whether the screws can be completely unscrewed. Mistakes the first time can quickly lead to drill holes or broken screws, which then become very complicated to fix.
I can confirm this—I bought completely new screws right away, which made the installation easier.
Overall, I would recommend taking your time with the replacement and not rushing. If you feel uncertain, it’s better to watch a video once and proceed systematically. That helped me, and now the drawers run quietly and smoothly again.
KARJU
11 Mar 2022 13:14
To supplement the previous tips, here are some structured notes:
1. Tools:
- Phillips screwdriver or cordless drill with low torque
- Possibly small pliers and fine sandpaper
2. Preparation:
- Completely empty and remove the drawers
- Prepare a workspace to avoid losing screws and small parts
3. Removing the old glides:
- Loosen screws slowly and evenly
- If screws are stuck, spray a little WD-40 and let it sit briefly
4. New glides:
- Use original parts, for example through the Ikea spare parts service, as the measurements must fit precisely
- Check screws for rust and replace if necessary
5. Installation:
- Attach new rails exactly parallel to the cabinet side wall
- Initially tighten screws by hand only, then check running quality
- If needed, lubricate the bearing or support with a special silicone spray
6. General:
- The MALM series uses different rails depending on the drawer size (full extension or partial extension)
Laujeffr52 schrieb:
so that the drawers run properly and quietly again afterward
Once adjusted, these rails are generally very durable and low-maintenance. It is important that no foreign objects are inside the sliding system.
Ellis
12 Mar 2022 16:04
Remove the drawer, loosen the screws of the glide runners, and take out the old glide runners. Attach the new glide runners, tighten the screws loosely, insert the drawer and test it, adjust precisely, then tighten the screws firmly.
Done.
