ᐅ How can I prevent my IKEA Brimnes furniture from wobbling?
Created on: 26 May 2023 08:37
Fomo31
Fomo31
26 May 2023 08:37
Hello everyone, some time ago I bought the IKEA Brimnes bedroom set and overall I am satisfied with it. However, I have noticed that some pieces of furniture, especially the wardrobe and dressers, tend to wobble slightly, particularly when they are used or when pressure is applied on the floor or when pulling on them.
I suspect this might be due to the floor surface, the assembly, or the furniture construction itself. Therefore, I would like to know: What is the best way to prevent my IKEA Brimnes furniture from wobbling without having to do major modifications?
Are there any specific tips or simple methods that have proven effective in increasing the stability of the furniture? Advice on proper assembly or recommended leveling materials would also be very helpful.
I want to reduce the wobbling as much as possible in the long term because, honestly, it gets a bit annoying over time, and I would like to use the furniture for a longer period. Thanks in advance for your tips!
U
uslis47
26 May 2023 09:53
Fomo31 schrieb:
I suspect that the issue is either due to the floor surface, the assembly, or the furniture construction itself.
Hello Fomo31, you’ve already narrowed it down well, as these are indeed the most common causes for wobbly furniture, especially with flat-pack furniture like IKEA’s Brimnes.
Regarding assembly: Make sure all screws and angle brackets are firmly tightened. Sometimes, for example, back panels are only attached with small nails. These provide visual stability but are not load-bearing supports. Even if different screws are included, you should use exactly the ones intended and tighten them carefully.
Regarding the floor: If the floor is uneven or there are grout lines between tiles or minor height differences, this can cause wobbling. Adjustable feet, special furniture legs, or small felt pads placed under the furniture can help here. They compensate for unevenness and also protect the floor.
Additionally, securing the furniture to the wall with anchors can help. IKEA often provides suitable brackets, which add extra stability.
Here is a brief summary:
- Check and retighten all fastening points
- Use underlay materials such as felt pads or small wooden shims
- Anchor furniture to the wall for increased stability
With these tips, you should be able to significantly reduce the wobbling. If you have more details about the assembly or the floor surface, I’m happy to provide further advice.
dijan
26 May 2023 10:21
uslis47 schrieb:
Also, securing the furniture with wall anchors can help.
Hello! Sure, wall anchors are the pro tip for a quieter room 😊.
Regarding furniture legs: I placed small rubber glide pads under my Brimnes bed, which not only compensate for uneven floors but also stop wobbling. It feels almost like an upgrade, a kind of furniture “anti-wobble miracle.”
One more extra tip: sometimes you can also put very thin strips of cardboard or foam rubber under wobbly furniture – they work like tiny shims and also provide some cushioning.
Good luck stabilizing, and if you want, feel free to share what worked best for you! 🌟
emmett
26 May 2023 11:45
With Brimnes furniture, always check:
- tighten all screws
- secure the back panel properly
- anchor the furniture to the wall using the supplied wall brackets
- use felt pads or adjustable furniture feet on uneven floors
This is usually sufficient.
brianna
27 May 2023 08:04
Fomo31 schrieb:
I want to minimize the wobbling as much as possible in the long term because, to be honest, it annoys me after a while and I’d like to use the furniture for a longer time.
Wobbling can often cause emotional stress, especially when you strive for order and stability in your own home. I completely understand that; many people feel the same.
What helped me was patiently going through everything step by step to identify what might not have been assembled perfectly—and using small aids that aren’t immediately noticeable, like adjustable furniture feet you can fine-tune in the evening.
Sometimes these small wobbles add up and feel worse than they really are. So: simply pay attention and don’t get discouraged. If you like, feel free to share here if you find a tip that works particularly well for you.
In any case, I hope your Brimnes furniture becomes as stable as you want it to be soon.
