ᐅ How can I prevent children from getting injured by the Ikea Brimnes drawers?
Created on: 20 Jun 2023 09:18
resenaHello everyone,
I have a fairly specific question: How can I prevent children from injuring themselves on the Ikea Brimnes drawers?
The drawers are known to be quite heavy and sometimes close somewhat abruptly. My young daughter often tries to grab the drawers or place things between them, which has already caused a few painful pinches.
I’m particularly interested in practical solutions that can be implemented using existing materials or affordable retrofit options, without having to replace the drawers entirely. Safety is important to me, but so is everyday usability, since the drawers are used frequently.
Does anyone have experience with this furniture or similar situations and can share tips on how to effectively avoid injuries with these kinds of drawers?
Thanks in advance!
Thanks in advance!
resena schrieb:
How can I prevent children from getting hurt by the Ikea Brimnes drawers?I know this problem all too well, and as a parent, it can be frustrating to see these small accidents happen. The Brimnes drawers are generally quite sturdy, but the edges and the heavy closing mechanism can definitely pose a risk to little fingers.
What worked well for us was a combination of several measures: First, we installed drawer locks, which are available quite affordably at hardware stores or online. These prevent the drawers from being pulled out completely, protecting children from getting pinched when closing.
Additionally, we added soft silicone edge protectors designed specifically for furniture. This significantly reduces the risk of impact injuries and pinching.
And very importantly, we regularly talk to our children about handling the furniture carefully. This usually doesn’t come naturally to them.
I can only encourage you to try this combination. It’s a good solution that has actually prevented injuries for us and doesn’t limit everyday life too much.
resena schrieb:
How can I prevent children from getting injured by the Ikea Brimnes drawers?A structured approach can be very helpful here. Here is a brief overview with practical steps to improve safety for Brimnes drawers:
- Install drawer locks: There are various types available, from push-button to hook-and-loop solutions, which prevent the drawers from opening fully.
- Add dampers: Ikea often offers optional soft-close dampers for many drawers like the Brimnes. If not, similar dampers can be retrofitted to reduce the risk of pinching.
- Apply edge protection: Soft silicone or rubber bumpers on the corners can reduce the risk of injury from bumps.
- Equip drawers with child-friendly handles: Handles that are easy for children to use and do not require sudden movements make handling safer.
- Explain proper behavior: Naturally, educating children about careful use complements the technical safety measures very well.
Please always check product compatibility with the Brimnes furniture when installing, as dimensions and mechanisms can sometimes vary.
In summary, the best results come from combining mechanical protection (locks, dampers) with soft protectors and educating the children.
Regarding the topic "How to prevent children from getting injured by Ikea Brimnes drawers?" I would like to add some technical and practical suggestions:
The Brimnes series uses drawer slides and closing mechanisms that can pose a risk to children without additional safety devices. This is mainly because the drawers are often heavy and tend to close with little damping.
1. Retrofit damping:
Although Ikea does not explicitly offer dampers for Brimnes, it is technically possible to adapt so-called soft-close dampers or buffers from the furniture accessories market. For example, inline dampers can be installed on the sides to gently slow down the drawer.
2. Drawer locks:
Installing child safety locks is essential. I particularly recommend flexible systems that prevent the drawer from being fully pulled out while still allowing it to be used. Clamping mechanisms, which can be discreetly mounted inside, are especially suitable.
3. Edge protection:
Foam or silicone profiles can be applied directly to the narrow gaps and edges. It is important that they have strong adhesive power and are made from non-toxic materials to keep it safe for children.
4. Regular inspection:
Especially after retrofitting accessories, fastenings should be checked regularly to ensure that nothing shifts or comes loose.
5. Behavioral education:
Unfortunately, even the best technology cannot replace educating children. A combination of good equipment and teaching is needed.
If you provide me with the exact model (e.g., number of drawers, usage habits), I can offer more specific product recommendations or point out potential pitfalls during installation.
2. Drawer locks:
3. Edge protection:
Laukau5 schrieb:
Especially after retrofitting accessories, the fastenings should be checked regularly to ensure nothing has shifted or come loose.This is such an important point. Sometimes when everything has been secured once, people assume no further action is needed. But especially with children who are active every day, fixtures can come loose.
Looking back at my post, I would emphasize again: be patient with yourself and don’t get discouraged if all the protection doesn’t seem foolproof. Over time, you learn where problems actually occur and can then address them more effectively.
It might also be interesting to add whether your drawers are often left open, which can increase the risk? Sometimes gently encouraging children to close drawers completely can help reduce pinch hazards.
