ᐅ How can I optimize storage space in Ikea Metod tall cabinets through smart planning?
Created on: 5 Apr 2021 18:27
hauja56
hauja56
5 Apr 2021 18:27
I am facing the challenge of optimizing storage space in Ikea Metod tall cabinets as effectively as possible. These cabinets are used in various ways in my kitchen, but despite their generous dimensions, I find that the usable storage space is not always efficiently utilized. My question is: How can I optimize storage space in Ikea Metod tall cabinets through smart planning, especially considering different shelves, internal drawers, and other storage options? Are there practical strategies or experiences on how to maximize space, for example by adjusting shelf heights, using narrow pull-outs, or special storage modules?
I look forward to your tips and concrete examples that go beyond the standard recommendations.
Torsten45
5 Apr 2021 18:53
A structured approach to optimizing storage space in Ikea Metod tall cabinets is essential.
First, the interior should be divided into several zones based on what will be stored (e.g., pots, dishes, pantry items). The heights of the shelves can be individually adjusted in Metod cabinets, which should be used to adapt the space between shelves flexibly according to the contents.
Additionally, internal drawers are a practical addition, as they make better use of the cabinet’s depth and improve accessibility. Special organization systems, such as pull-out shelves, drawers with dividers, or vertical bottle holders, can also make space more efficient.
A tip: The back panel of the cabinet can be equipped with extra hooks or grids to keep small kitchen utensils within easy reach.
Overall, it is important to accurately assess the actual needs before planning and then select modular systems accordingly.
kibutar
6 Apr 2021 07:42
Hello hauja56,
I like to approach this question in detail because optimizing storage space in Ikea Metod tall cabinets requires a targeted approach that involves understanding the system’s possibilities.
First: The shelf heights can be adjusted in 2 cm (1 inch) increments, allowing you to tailor the space precisely to your contents. You should start by analyzing the typical storage needs.
Furthermore, I recommend the following steps:
- Use inner drawers and pull-outs, available in various heights, to store smaller items neatly and accessibly.
- For deeper cabinets: install pull-out systems with a soft-close mechanism so you can fully utilize the back space without awkward reaching.
- The upper section of the tall cabinet can be effectively used with pull-out baskets for items that are used less frequently.
- To make even better use of the depth, multi-level pull-outs or stackable storage boxes work well.
A small tip: For regularly used food items, transparent containers that match the cabinet width exactly are recommended. This also helps avoid wasted space between different stacked layers of smaller items.
I’m interested to know which Ikea products/sets you are using exactly, and the height and depth of your tall cabinets, so I can provide more specific advice.
Giagau
6 Apr 2021 10:15
kibutar schrieb:
You can make great use of the upper section of the tall cabinet by installing pull-out baskets for items that are rarely used.
This is an important point: Often, the upper section remains unchanged and is hardly considered during planning. Especially with Metod tall cabinets, this area should be fitted with pull-out baskets or roll-out inserts to avoid wasting a lot of space.
Additionally, I recommend paying close attention to the load limits of the shelves during planning to avoid placing items that are too heavy for the material.
For organizing depth-wise, stepped pull-outs are beneficial. Combining these with adjustable-height internal drawers makes it easier to accommodate items of varying sizes.
Ethan
7 Apr 2021 12:03
hauja56 schrieb:
How can I optimize storage space in Ikea Metod tall cabinets with smart planning, especially considering different shelves, inner drawers, and other storage options?
I’m happy to provide an overview with practical recommendations for efficient use:
- Adjustable shelves: Arrange them to avoid wasting vertical space. Large pots go in the lower section, smaller containers higher up.
- Inner drawers and pull-outs: Particularly useful for pans, cutting boards, and small items.
- Cabinet doors: You can add storage pockets, small hooks, or rods here to create extra space for wraps, spices, or utensils.
- Modular organizing boxes: Perfect for sorting pantry items by category.
For planning, it’s worth using Ikea’s planning tools or a sketch with measurements. It’s important to sort your kitchen utensils into categories beforehand and then choose the right solution accordingly.
Do you have any specific items that require a lot of space?
