ᐅ How can I best install IKEA Metod cabinets in a limited space?
Created on: 27 May 2021 08:43
Sofera
Hello everyone, I am currently planning to install several IKEA Metod kitchen cabinets in a very tight space measuring about 180 cm (70.9 inches) wide and about 240 cm (94.5 inches) high. The challenge is to make the best possible use of the available space without the cabinets feeling too bulky or cramped. The walls are partly uneven, and ventilation ducts further limit the usable depth. I am wondering which installation strategies, organization methods, or planning tips are especially recommended in this situation. I am particularly interested in how to best align the cabinet frames, how to most elegantly use side panels or filler strips, and whether certain cabinet types or Metod accessories might be better suited to make the space both visually appealing and practical. Looking forward to your suggestions and experiences!
NOAHSAU
27 May 2021 13:26
Sofera schrieb:
I’m also interested to know if there are any specific accessories for Metod that are especially recommended for small spaces?
This is actually a point IKEA doesn’t emphasize enough. The real innovation in small or cramped spaces often doesn’t lie in the cabinets themselves, but in the accessories: smooth-running interior drawers, narrow shelves, and especially the ability to position shelves individually (for example, with brackets that are not fixed in place).
I would even say that Metod’s rigid grid system is both a blessing and a curse – because it strictly dictates the design, it sometimes lacks the desired flexibility. Therefore, you often have to make compromises or modify the interior components yourself.
LUISABEL
28 May 2021 07:34
Precise planning is essential. For tight spaces, I recommend:
- Using tall cabinets with internal pull-outs to better utilize vertical storage space.
- Incorporating corner cabinets or units with rotating elements, such as carousel or magic corner systems, since they make dead corners more accessible.
- Planning and installing filler strips with millimeter precision to avoid trip hazards or unsightly gaps.
- Paying attention to the load capacity of individual modules, especially when mounted at height.
An important point: Before installation, check that all walls are truly straight, and if there are slight irregularities, use adjustable feet. Also, install cabinets with enough clearance from doors, windows, or radiators.
Thierryzar
28 May 2021 09:46
My tip: Plan ahead so that you partially assemble the cabinets on the floor first. Then hang them on the wall in small sections and secure them with angle brackets and screws. If space is limited, choose narrow tall cabinets instead of wide base cabinets. This saves floor space while still providing plenty of storage.
