ᐅ How can I best install IKEA Metod cabinets in a limited space?
Created on: 27 May 2021 08:43
SoferaHello everyone, I am currently planning to install several IKEA Metod kitchen cabinets in a very tight space measuring about 180 cm (70.9 inches) wide and about 240 cm (94.5 inches) high. The challenge is to make the best possible use of the available space without the cabinets feeling too bulky or cramped. The walls are partly uneven, and ventilation ducts further limit the usable depth. I am wondering which installation strategies, organization methods, or planning tips are especially recommended in this situation. I am particularly interested in how to best align the cabinet frames, how to most elegantly use side panels or filler strips, and whether certain cabinet types or Metod accessories might be better suited to make the space both visually appealing and practical. Looking forward to your suggestions and experiences!
You should first take precise measurements of the room and carefully record the dimensions. Then, plan cabinets with smaller widths, for example 40 or 60 cm (16 or 24 inches) instead of wider ones. Corner solutions or tall cabinets with pull-out interiors also work well when space is limited. Use filler strips to cover any uneven gaps, but make sure to measure these accurately beforehand.
I think you often see the same standard advice, but when space is limited, it can be worth thinking more radically. Why not arrange Metod cabinets in a slightly asymmetrical way? A bit of chaos in the layout can make the space more interesting and even improve its functionality. Also, limited space doesn’t automatically mean a more expensive cabinet. Just try focusing on vertical space and don’t stick to traditional methods during assembly.
Regarding optimal installation and use in confined spaces, I recommend the following step-by-step approach:
- Step 1: Precisely measure the room dimensions and carefully note any existing obstacles (pipes, shafts).
- Step 2: Choose appropriate Metod cabinet modules with reduced widths, for example 20-40cm (8-16 inches) where space is tight. Tall cabinets can help create additional storage vertically.
- Step 3: Begin cabinet installation by aligning the base frames. Use a spirit level and spacers.
- Step 4: Cut and fit filler strips (including ultra-thin options) precisely to compensate for unevenness and ensure a clean finish.
Common mistakes: Insufficient planning and inaccurate measuring, which can result in gaps or cabinets not closing properly. Also, with Metod, it is essential to tighten the connecting screws properly—if too loose, it leads to unstable constructions.
KODAN32 schrieb:
Typical mistakes: insufficient pre-planning and not measuring carefully enough, which results in gaps or cabinets not closing properly. I completely agree, I really want to avoid ending up with wide gaps or uneven finishes. I’m also interested if there are any specific accessories for Metod that are especially recommended for small spaces? Particularly filler strips or corner pieces that aren’t commonly seen? And how have you dealt with ceiling height variations when the ceiling is uneven?
The proper selection and adjustment of accessories is very important. In tight spaces, the following points are especially useful:
- Fill strips with flexible widths that can be used both horizontally and vertically.
- Special angle connectors or bracket fittings that require little space but still ensure stability.
- Height-adjustable furniture legs help compensate for slight ceiling slopes or uneven floors without distorting the cabinet frame.
- Make sure the cabinets fit as closely as possible to the ceiling to avoid dust accumulation – in this case, finishing panels are very helpful.
A small tip: If the ceiling is uneven, it is often advisable to mount the cabinets slightly “floating” on the wall to conceal any irregularities underneath.
