ᐅ How can I best install an IKEA Metod L-shaped kitchen unit?
Created on: 5 Oct 2021 18:23
solopi
solopi
5 Oct 2021 18:23
I am currently planning to install my new IKEA Metod kitchen in an L-shape and have a few questions about the best approach. Specifically, I want to know how to best arrange and assemble the base cabinets and wall cabinets to ensure the workflow in the kitchen is as efficient as possible. What should I keep in mind when measuring and aligning, especially at the corner where the L-shape connects? Are there practical tips for stability, for example regarding how to fasten the cabinets to each other and to the wall?
Additionally, I would like to know if there are recommended strategies for neatly integrating the electrical and plumbing connections in the corner solution without compromising accessibility or storage space later on.
I have some experience with furniture assembly, but this particular project seems quite challenging. I would greatly appreciate any specific experiences, tips, or advice about common pitfalls when installing a Metod L-shaped kitchen!
Jorgela
5 Oct 2021 19:02
The most important step is to take precise measurements first, especially the angles in the corners. Cabinets must be aligned on a horizontal level. For connecting the L-shape, a special corner connector set, like the one IKEA offers for Metod, is recommended. Don’t forget wall mounting, especially for tall wall cabinets.
taudi
6 Oct 2021 09:44
Hello solopi,
When installing the IKEA Metod kitchen unit in an L-shape, I recommend the following steps:
- First, measure the room and all walls very precisely, including the corner, to check if it is really 90 degrees or slightly angled.
- Before assembling the cabinets, check the floor level and, if necessary, level it with shims so the cabinets do not wobble.
- Align and securely screw the base cabinets on the longer side first.
- For the corner, use special corner cabinets (such as the carousel cabinet), which are ideal to plan in to make the most of the storage space.
- Always connect the cabinets to each other, not just attach them to the wall; this provides greater stability.
- Install the wall cabinets only after the base cabinets are in place, mounting them with mounting brackets on the wall and aligning carefully.
- Plan electrical and plumbing connections precisely before installation, so you can route outlets or hookups discreetly inside or behind the cabinets.
Common mistakes:
- Base cabinets are not at the same height, causing problems with countertops and sliding doors.
- Insufficient wall clearance or incorrect angles, leading to issues with cabinet doors.
Summary: Accurate measurements, secure cabinet connections to each other and the wall, and careful planning of connections ensure everything fits perfectly.
Timmyse36
6 Oct 2021 16:12
Thanks for the helpful tips so far. I personally had a lot of stress assembling my L-shaped kitchen with Metod, mainly because I measured the corner incorrectly. The cabinets ended up misaligned, and I had to take almost everything apart again.
What I can recommend is to really take your time when leveling and repeatedly check for evenness with a spirit level. It might also be a good idea to assemble everything temporarily first before fully tightening all the screws.
Regarding the electrical work: I found it extremely helpful to route all cables for outlets and lighting carefully before assembly and to mark their positions clearly – this makes you much more flexible later on.
Dopoki
7 Oct 2021 08:37
solopi schrieb:
Are there any practical tips for stability, for example regarding the attachment of the cabinets to each other and to the wall?
For maximum stability, I recommend:
- Always connect the cabinets directly to each other using the connection materials provided by IKEA.
- Additionally, use wall anchors that are securely fixed in the wall (e.g., wall plugs for concrete or cavity anchors for drywall).
- Align the cabinets precisely with a spirit level and adjust the legs of the base cabinets so the countertop sits perfectly level.
timmyse36 schrieb:
Take your time to align everything and keep checking the level with a spirit level.
This is absolutely crucial, as even small deviations can later lead to gaps and misalignments.
Regarding electrical and plumbing connections:
- Be sure to plan a detailed layout of the connections before assembly.
- Use cable channels inside the cabinets to route cables invisibly.
- For water connections, angle valves are helpful to make components more accessible.
A thorough preparation prevents later modifications and makes maintenance easier.
Lorukeo
7 Oct 2021 13:58
taudi schrieb:
Base cabinets are not at the same height, so countertops and sliding doors won’t fit properly.
This is an important point. I would also add that, especially with the L-shaped layout, you need to pay close attention to how the countertops join at the corner. Even a slight misalignment can result in a gap.
Additionally:
- When choosing the corner, consider corner cabinets with carousel or LeMans pull-out shelves to make good use of the space.
- Avoid collision points between doors and cabinet elements in the corner area.
- If possible, plan sufficient clearance behind the sink and stove in case water connections or electrical installations are needed.
For the installation: Use a stable leveling tool or laser level; this really helps with angles and alignment.
Thorough planning and following the points above will ensure a smooth installation and good functionality.
