ᐅ How can I make BILLY shelves sturdy for households with children?
Created on: 2 Sep 2015 08:43
kirsten9
kirsten9
2 Sep 2015 08:43
Hello everyone, I want to make my IKEA BILLY shelves especially sturdy in a household with small children, as they tend to tip over easily or get dents. My question is: How can I secure BILLY shelves against tipping as effectively as possible and make them overall robust so that playing children don’t accidentally damage anything or get hurt? Are there any special techniques, accessories, or structural modifications you would recommend to improve the safety and durability of these shelves? I look forward to your experiences and tips!
manla
2 Sep 2015 09:18
Hello Kirsten, it is very important that BILLY shelves are always secured to the wall, especially in households with children. IKEA usually provides appropriate wall fasteners, which you should definitely use. Additionally, I recommend the following points:
1. Use strong anchors and screws suitable for your wall type (e.g., concrete, drywall).
2. Avoid overloaded shelves, especially in homes with children – this can increase the risk of tipping.
3. If you want the shelf to be particularly sturdy, you can also install metal brackets inside to reinforce the joints.
4. For child safety, I recommend covering the front edges with corner protectors made of foam or rubber.
With these steps, you are already on a very good path!
Tause
2 Sep 2015 10:02
manla schrieb:
It is important that BILLY shelves are always secured to the wall, especially if there are children in the household.
That is basically correct, but I would take it a step further: The type of wall fixings should definitely be suited to the wall material and the expected load. Basic anchors from discount stores or general hardware stores are often not sufficient if children pull or climb on them.
Additionally, I wonder if the stability of the shelves themselves could be improved instead of relying solely on the wall attachment. For example, by adding extra bracing or even installing a back panel made of strong material.
I often see people just use a single screw quickly and then feel falsely secure, even though the shelf gives way under load. Better safe than sorry – proper planning is essential.
PULAU
3 Sep 2015 07:52
I would like to add that for households with children, a combination of wall anchoring and reinforcement of the shelving structure is very effective.
kirsten9 schrieb:
How can I best secure BILLY shelves against tipping over and make them overall sturdy enough so that playing children do not accidentally damage anything or get hurt?
- The best approach is to widen the base of the shelf. For example, you can mount a plywood base plate at the bottom yourself to give the shelf a wider footprint.
- Replacing the thin particleboard backing with a plywood panel significantly improves lateral stability.
- I would also recommend separate corner guards for edge protection, as softer materials wear out more quickly.
Although this requires some effort, it greatly increases safety and can prevent accidents.
temeli
3 Sep 2015 11:19
This is really great to see so many practical tips here! 🙂 Recently, I reinforced BILLY shelves for my little niece’s home using threaded rods.
I carefully drilled deep holes on the sides and used these threaded rods along with matching nuts to clamp the entire shelf together during assembly. This makes the side panels much more stable and also helps the shelf hold together better.
Additionally, I covered all sharp corners with self-adhesive rubber edge protectors. This not only feels softer but also looks better than untreated wood surfaces.
If you’d like, I’m happy to share more details on exactly how I did this! 🙂
