ᐅ How do I install a DIY LED strip in Ikea Metod wall cabinets?
Created on: 18 Sep 2021 20:07
karlhein62
karlhein62
18 Sep 2021 20:07
I am currently planning to install a DIY light strip in my Ikea Metod wall cabinets to improve both the appearance and functionality of my kitchen. I want to create discreet but effective lighting that integrates well with the cabinet design. My idea is to use LED strips that can be controlled by a switch or motion sensor. It is important to me that everything is installed neatly, cable management works properly, and above all, that the power supply is safe and durable.
Does anyone have experience installing LED light strips in Metod wall cabinets? What should I consider regarding mounting options, power supply (230V or low voltage?), voltage converters, and are there any practical recommendations for switches or sensors?
I’m also interested in how you routed the cables in and behind the cabinets without risking damage to the furniture.
Looking forward to your tips and advice!
koneo
18 Sep 2021 21:43
Hello Karlhein62,
First of all, it’s a good approach that you are considering the neatness of the installation and cable management. When installing LED strips inside Ikea Metod wall cabinets, the most important thing is to carefully plan the power supply and the mounting.
- For the power supply, I usually recommend 12V LED strips. They are safer than 230V and there are many power supplies available that you can easily conceal.
- It’s best to screw the power supplies to the back or top of the cabinets. Route the cables through existing cable channels or install small cable ducts yourself.
- For mounting the LEDs, the adhesive backing on the LED strips usually works well, but especially inside cabinets, it helps to use aluminum profile channels that also dissipate heat.
- For the switch: motion sensors are elegant and practical. You need to ensure the sensor is well positioned so it doesn’t misread due to light reflections or shadows.
Regarding cable management: Ikea Metod cabinets often have screw holes or gaps where you can neatly route cables so they are not visible. However, I would not recommend drilling holes into the cabinet panels; instead, use the existing channels or attach cable clips inside.
If you want more details about choosing LED strips or power supplies, I’m happy to help.
glamo
19 Sep 2021 07:32
to address the topic in more detail: Installing LED light strips in the Ikea Metod wall cabinets requires more planning than you might initially expect. Here is my step-by-step recommendation, which I used for my own project:
- Preparation: Measure and mark exactly where the light strips should be placed, preferably on the underside of the cabinet shelf so that the light shines downward.
- Material selection: 12V LED strips with at least IP20 rating (preferably IP44 for splash protection), with a light color according to your preference (warm white 2700-3000K for a cozy atmosphere or neutral white 4000K for optimal kitchen lighting).
- Mounting: I used thick aluminum profiles on both sides as carriers. These profiles not only provide more stability for the LEDs but also help with heat dissipation. The adhesive tapes alone often lose their grip over time, especially with occasional moisture in the kitchen.
- Wiring: Since Metod cabinet carcasses are made of particle board, I use self-adhesive cable channels designed for indoor use. It is important to route the cables so that they are not pinched, especially near the hinges or where the doors close tightly.
- Power supply: Use a suitable 12V power supply unit that provides at least 20% more power than the total wattage of your LEDs. A more powerful transformer runs cooler and lasts longer.
- Control: Both switches and motion sensors are suitable. Motion sensors should be installed within the line of sight, but generally, a simple toggle switch mounted at the bottom edge of the cabinet is easier and more reliable.
Finally, an important question: What kind of power source do you want to use? A cable connected directly inside the cabinet, or a separate outlet to which the power supply is connected? This will influence how you plan wiring and circuit protection.
karlhein62
19 Sep 2021 09:51
[quote=glamo, post: x1j4g1, member: XXX]One final important question: What power source do you want to use? A line connected directly inside the cabinet or a separate outlet to which the power supply is connected? This influences, among other things, how you need to plan wiring and fuses.
Thank you for the detailed post, glamo,
I tend to provide power to the power supply via a separate outlet, as I don’t want to alter or break into my existing kitchen installation. The power supply could then be hidden behind the cabinet or inside the adjoining space. I will probably use cable channels or cable clips to route the cables discreetly.
The slight oversizing of the power supply you recommended seems reasonable, especially considering heat generation and longevity.
For the control, I would prefer a toggle switch on the cabinet edge; I want the simplest and most robust solution possible.
Do you have experience with suitable toggle switches for 12V applications that would fit well with the Metod furniture design?
Gregory
19 Sep 2021 12:15
karlhein62 schrieb:
Do you have experience with suitable toggle switches for 12V applications that fit well with the Metod furniture design?
For 12V applications, miniature toggle switches are generally recommended. These can often be found with white or transparent caps through specialty suppliers, which better match Ikea-style designs. It’s important to choose a switch rated for the current of your LED strip (usually under 2 amps is sufficient).
Many users prefer push buttons combined with bistable relays (acting like toggle switches) because they offer a smoother switching feel and can be mounted flush easily. An advantage of push buttons is that the LED selection state can be shared (optionally with remote control).
Important: Make sure the switch has a good IP rating if it will be accessible from the outside and might be exposed to occasional moisture.
I recommend placing the switch outside the direct cabinet interior (for example, on the side of the frame). This fits very well with the Metod style and ensures easy access.
