ᐅ How can I gently remove adhesive residue from Malm drawers?
Created on: 28 Oct 2024 14:07
Fakeo45
Fakeo45
28 Oct 2024 14:07
I have a small problem: I have adhesive residue on the wooden surfaces of my IKEA Malm drawers, probably from stickers or labels I removed, but unfortunately the glue wouldn’t come off completely. Now I’m looking for a way to gently remove this adhesive residue from the drawers without damaging or ruining the surface.
It is important to me to avoid harsh chemicals or only use those that won’t harm the paint or veneer. Does anyone have experience or tips on which products or home remedies work well? Ideally with detailed instructions or even warnings about what definitely should not be done?
Thanks in advance!
koduga
28 Oct 2024 14:29
Fakeo45 schrieb:
Now I’m looking for a way to gently remove these adhesive residues from the drawers without damaging or making the surface unsightly.
I know it’s really frustrating when you can’t get these adhesive residues off the Malm drawers without worrying about the material. I had a similar situation once, and a simple trick helped me: warm water with some dish soap and a soft cloth.
I dampened the cloth well, placed it on the adhesive residue, and let it sit for a few minutes, then gently rubbed it off. It took a bit of patience, but everything came off without damage.
Maybe that’s a good first step for you too before trying stronger agents. How about you – have you tried that yet?
gasidney
28 Oct 2024 15:05
Ever used a hairdryer? Heat softens the adhesive, allowing you to gently wipe it off. Avoid solvents that could damage the surface.
Dilen
28 Oct 2024 17:52
Hello Fakeo45,
I can recommend a more detailed process on how to effectively and gently remove adhesive residues.
First, for preparation: work at room temperature and ensure a clean, stable surface so the drawer doesn’t slip during cleaning.
I usually start with a slightly warmed, damp microfiber cloth—not too wet—to remove coarse dirt by moistening the area with residue to soften the adhesive a bit. This reduces the risk of rubbing too hard.
Then, depending on the strength of the adhesive residue, you can try rubbing in a little oil—olive oil or baby oil works well—to break down the sticky residue. Let it sit for about 10 minutes, then wipe off with a clean, soft cloth.
If that’s not enough, I recommend using isopropyl alcohol (about 70%), applied sparingly on a cotton pad. The mild alcohol helps dissolve the adhesive without damaging paint or wood. But always test first in an inconspicuous spot. Never rub with nail polish remover or acetone, as this can permanently damage the surface.
A very important point: don’t use sharp screwdrivers or scrapers—that will cause scratches! Also, avoid chemical plasticizers or highly alkaline cleaners.
One more question: Are the adhesive residues oily or solid, and is the adhesive shiny or matte? Such details help to recommend which product is more suitable.
KAULIS
29 Oct 2024 10:14
Fakeo45 schrieb:
It is important to me to avoid aggressive chemical agents or to use only those that do not damage the paint or veneer.
Regarding the material compatibility of Malm drawers made of MDF with a melamine coating, it is important to choose cleaning agents that do not harm these surfaces. According to technical data sheets, isopropyl alcohol in low concentration and mild soap solutions are suitable.
For the procedure, I recommend starting by treating adhesive residues with a soft cloth and warm water plus a pH-neutral dish detergent, letting it sit for several minutes, and then gently wiping it off.
If stronger residues remain, test the use of isopropanol on an inconspicuous area, apply carefully with a lint-free cloth, and wipe off immediately to avoid prolonged exposure.
Mechanical removal (scratching, scraping) is not advisable due to the sensitive coating. Acidic or aggressive solvents (acetone, turpentine) should definitely be avoided, as they can permanently damage the surface and paint.
This approach represents a good compromise between effectiveness and material protection.
warrenka57
29 Oct 2024 11:20
koduga schrieb:
I once had a similar situation, and a simple trick helped me: warm water with a bit of dish soap and a soft cloth.
I can confirm that. I had adhesive residue left after removing price tags and did the same. What really helped was gently rubbing over the area afterward with an eraser—not a regular eraser, but a special cleaning eraser that removes small adhesive residues without scratching.
gasidney schrieb:
Ever tried a hairdryer? Heat softens the adhesive.
That’s true, but be careful with the heat. I removed the drawers first, otherwise the coatings could come off due to the heat.
I think a combination of heat, some dish soap, and a cleaning eraser is often the most effective and also very gentle.
