ᐅ How do I fix loose screws on Malm beds?
Created on: 9 Dec 2021 18:27
dirk3
dirk3
9 Dec 2021 18:27
Hello everyone, I have an issue with my Ikea Malm bed where the screws, especially at the joints between the headboard and the side panels, keep loosening over time. This causes the bed to wobble slightly, and I have to regularly tighten the screws. I suspect the material might be flexing under load or the screws are loosening due to slight vibrations. Does anyone have tips on how to prevent the screws from loosening permanently? Are there special thread lockers or other methods that can be used on a Malm bed without compromising stability or damaging the wood? I would appreciate specific advice and experiences.
barEsperan
9 Dec 2021 18:44
Hello, I recommend first loosening the screws completely and then applying some wood glue into the holes or threads. After that, tighten them firmly and let them dry. Alternatively, inserting small plastic washers to increase friction can also help. Threadlocker, such as screw locking fluid, can also be effective.
gadalu
10 Dec 2021 09:31
The problem of loose screws in Malm beds often stems from the combination of thin, sometimes veneered wood and the stress caused by movement. A common mistake is simply tightening the screws again without taking measures to secure them properly.
First, I recommend the following structured approach:
1. Completely unscrew the screws to check the attachment points. If they are worn out or damaged, using a dowel or wood filler may be necessary.
2. If the material is intact, applying a drop of medium-strength threadlocker (e.g., Loctite) on the screw threads can help prevent loosening. It can still be removed later with some force.
3. Alternatively, for worn-out holes, inserting wooden or threaded dowels or filling the holes with wood filler before reinserting the screws can be effective.
4. Avoid over-tightening, as this can damage the material more quickly.
5. If the bed is very wobbly, check that all connection points are correctly seated and the screws are placed in the proper locations.
This method maintains functionality in the long term without causing damage.
dirk3 schrieb:
Hat jemand Tipps, wie ich dauerhaft verhindern kann, dass die Schrauben locker werden?
Therefore, it is important not just to tighten the screws, but to stabilize the mechanical connection through threadlocker or by repairing the material.
Luciandi
11 Dec 2021 13:16
I’m very familiar with the problem of loose screws—I experienced the same with my Malm bed, and it was quite frustrating. It’s really annoying to have to tighten them repeatedly, especially when it feels like the screws keep loosening on their own.
What helped me was a combination of using threadlocker and carefully reworking the material. Sometimes it can feel a bit overwhelming since tightening screws seems so simple, but often it’s the small details that solve the issue.
gadalu schrieb:
A drop of threadlocker on the thread helps prevent loosening.
I can confirm that, but I’ve also made a habit of checking again after a few months to make sure everything is still tight. This is especially important if you move a lot or rearrange the bed frequently.
If anyone is worried about threadlocker causing permanent bonding—I never had a problem where the screws couldn’t be removed, some force is always enough 🙂
