ᐅ How can I disassemble and reassemble IKEA Platsa shelves without causing damage?
Created on: 5 Oct 2022 13:27
Nitojan
Hello everyone, I am currently facing the challenge of disassembling my IKEA Platsa shelves to reassemble them at a different location. Since the components are quite delicate and I want to avoid damage to the sides and connection points, I am looking for a careful and systematic approach.
Does anyone have experience with taking apart and putting together Platsa shelves without causing splitting, stripping screw holes, or damaging the surface?
I have seen that some professionals recommend loosening screws slowly and evenly, but are there any additional tips for handling the panels, storing the individual parts, or dealing with dowels and fittings?
I would appreciate detailed advice to ensure the move goes smoothly and that I can use the shelves again in as close to new condition as possible.
GLALEO
7 Oct 2022 08:34
Hey, I just completely disassembled and reassembled my Platsa shelves – no damage! The key is really patience and working carefully.
I also recommend using a soft surface when placing or moving the panels. This prevents scratches on the surfaces. And if you tighten all the screws at the end with light torque, it protects the connection holes.
You can do it! The second time you assemble them, it will go much faster and more smoothly!
Farmo
7 Oct 2022 12:21
When removing the anchors: It is best to gently pry them out with a thin screwdriver to avoid damaging the holes.
Do not stack the panels; lay them side by side.
Loosen screws carefully, without using excessive force.
GU-LAU60
8 Oct 2022 09:53
GLALEO schrieb:
I also recommend using a soft underlay when placing or moving the panels. This prevents scratches on the surfaces.
Absolutely right! In addition, you can place small pieces of polystyrene or foam under the corners to avoid pressure marks. This way, the shelving unit will stay looking like new for a long time.
