ᐅ How can I transform an IKEA Besta into a multifunctional sideboard for the living room?
Created on: 25 Jan 2023 09:07
Gitan
Hello everyone, my question is as follows: I want to modify my IKEA Besta shelving unit to function as a multifunctional sideboard in the living room. The goal is not only to create storage space but also to use the piece as a media unit, possibly with integrated cable management for the TV, gaming console, and speakers. Additionally, storage and display areas should be combined effectively, ideally providing space for decorative items and books. Does anyone have experience or recommendations on the best way to adapt the modules, which additional components work well, and any practical tips for the conversion? In short: How do I transform an IKEA Besta into a multifunctional sideboard for the living room?
Gitan schrieb:
I wonder how flexible the Besta system really is for remodeling.The Besta system is basically modular but is technically designed for its standard dimensions. For non-standard heights and depths, additional reinforcements are often needed, such as metal brackets or back panels. Combining it with other IKEA systems like Kallax or Hemnes can also be useful when different depths are required. However, it is important to carefully check the load capacity and stability, as changes in height or depth can reduce overall sturdiness.
For the renovation, I recommend installing adjustable shelves with perforations. This allows cables to be routed neatly behind the appliances. Additionally, using self-adhesive rubber feet or casters can make the furniture more mobile, which is helpful for cleaning or rearranging.
Wow, I find it really fascinating how versatile Besta can be! I equipped my sideboard with LED strips under the shelves and added practical drawers – this way you combine cool lighting with plenty of storage space! It makes the living room feel cozy and modern at the same time!
An important aspect of a renovation is the choice of materials for the surface. Solid wood or veneered panels not only enhance the aesthetics but also significantly increase durability. During installation, it is important to ensure that the weight of the new materials can be supported by the shelves and connectors.
ODINFLO schrieb:
For differing heights and depths, additional reinforcements are often required, such as metal brackets or back panels.That is correct. Additionally, I recommend using sturdy screw connections and, if necessary, bonding the components to ensure long-lasting stability. When converting to glass fronts, the door hinges should also be carefully selected and reinforced if needed.
GLALEO schrieb:
I equipped my sideboard with LED strips under the shelves and installed practical drawers – this way you combine a cool atmosphere with plenty of storage space!That sounds really interesting! Were you able to integrate the LED strips easily into the Besta system? How did you handle the cable management to keep everything looking neat? Are the drawers from the Besta accessories or independent additions? Any information on this would be very helpful.
