ᐅ How can I clean Malm furniture without causing scratches?
Created on: 10 Sep 2016 19:07
Nalu33
Nalu33
10 Sep 2016 19:07
Some time ago, I purchased several pieces of furniture from the Malm series by IKEA, which I now want to clean regularly. Since the surfaces are lacquered and quite delicate, I want to avoid scratches or unsightly marks during cleaning at all costs. Are there any proven methods or cleaning products that are especially suitable for Malm furniture to protect the surface? It would also be important for me to know which tools (e.g., cloths or sponges) I should use and if there are any cleaning liquids I should definitely avoid. I would appreciate any tips and experiences, as I want to keep the furniture in good condition for as long as possible.
PRA64
10 Sep 2016 19:59
Hello Nalu33,
regarding your question about how to clean Malm furniture without scratching it, here is a brief guide:
1. Preparation: Always use a soft microfiber cloth that is free of coarse dirt and very gentle on the surface. Avoid rough sponges or abrasive cloths.
2. Cleaning agents: The best option is clear, lukewarm water with a small amount of mild dish soap. Afterwards, wipe again with clean water to avoid leaving any residue. Avoid harsh cleaners, ammonia, or strong solvents, as they can damage the finish.
3. Cleaning technique: Do not apply too much pressure! Instead, proceed gently using circular motions. Never rub dust with a dry cloth, as this can cause scratches.
4. For stubborn stains: Use a slightly damp microfiber cloth and a specialized cleaner for lacquered surfaces – but always test on an inconspicuous spot first.
Summary: Soft cloth + mild cleaning agent + gentle wiping technique = a clean surface without scratches.
If you have any further questions, I’m happy to help.
Ryder35
10 Sep 2016 20:22
Use a damp microfiber cloth and mild dish soap. Avoid abrasive cleaners or rough sponges. Important: wipe gently.
leebi7
11 Sep 2016 08:43
I would also add that with Malm furniture, it is very important not only to clean the surface gently but also to prepare the cleaning process properly.
First, it is advisable to thoroughly remove dust from the surface using a soft duster or a very fine cloth before any moisture is applied. Sealants can react sensitively if dirt particles are spread by friction.
An important point: the cleaning solution should not be applied too wet. For lacquered surfaces, there is a risk that water can penetrate edges or joints and cause the wood to swell. Therefore, make sure to wring the cloth well.
For cleaning, I often use a plant-based solvent specially developed for wood lacquers – it is mild and reliably removes grease stains. Afterwards, the surface should be dried with a soft, dry cloth.
Have you ever had stains on your Malm surface that were particularly stubborn? I could explain in more detail how to treat these without damaging the lacquer.
The most important thing is always to avoid applying pressure or using the wrong products that can damage the protective layer. Microfiber cloths are great, but they must be really clean and free of sand or coarse dirt.
Nalu33
11 Sep 2016 12:17
leebi7 schrieb:
Have you ever had stains on the Malm surface that were particularly stubborn?
So far, I have mainly dealt with dust and occasional water rings from glasses, which I wiped off thoroughly. Once, there was a light grease film from the kitchen, but it was easily removed.
I suspect that the combination of slightly greasy fingers and household dust can be problematic. Which plant-based cleaners would you recommend for this? And how often should this cleaning generally be done without unnecessarily wearing down the furniture material?
Dwight49
11 Sep 2016 13:30
Additional information:
Malm furniture is usually made of particleboard with a foil or lacquer coating. Cleaning should primarily be gentle and mechanical to avoid damaging the surface.
Therefore, you should definitely avoid aggressive chemical agents containing solvents, as they can dissolve or dull the finish. pH-neutral cleaning products or mild soap solutions are recommended.
Regarding cleaning frequency: generally, a gentle cleaning once a week is sufficient. Depending on usage, you can carefully remove dust every few days. Excessive cleaning and unnecessary use of moisture can unnecessarily weaken the protective layer.
Do not use products containing bleach, alcohol, or ammonia. Microfiber cloths are ideal due to their fine texture, but make sure they are clean to prevent micro-scratches from dust particles.
