ᐅ How can I clean Ikea Hemnes furniture in an eco-friendly way?
Created on: 10 Apr 2023 14:23
nebe44Hello everyone! I recently purchased some Hemnes furniture from Ikea, which is primarily made of solid pine wood. My goal is not only to keep the furniture clean but to do so in a way that is sustainable and gentle on both the material and the environment. Therefore, I am looking for an effective cleaning method that avoids harsh chemicals and unnecessary water use.
I am interested in tips and recommendations on environmentally friendly cleaning products, the best cleaning techniques, suitable tools, and whether there are any special care instructions that help extend the lifespan of the furniture.
Does anyone have experience with sustainable cleaning of Hemnes furniture or similar solid wood furniture? What works well in everyday use? Thanks in advance!
For sustainable cleaning of Ikea Hemnes furniture, I recommend avoiding aggressive chemicals such as ammonia or harsh solvents, as these can damage the wood and its surface.
- Instead, use a mild cleaning solution, for example, a mixture of warm water and a drop of biodegradable dish soap.
- A soft microfiber cloth works great for removing dust without causing scratches.
- Avoid excessive moisture, as too much water can cause the wood to swell. Pro tip: wipe the furniture dry with a soft cloth after cleaning.
Additionally, consider applying a natural wood treatment once every quarter, preferably with linseed oil or beeswax, to protect the wood and enhance its grain.
This way, the Hemnes look is preserved, and the furniture lasts longer.
PeoDaniel10 Apr 2023 16:35Hello nebe44! It’s great that you’re considering sustainability when cleaning your Hemnes furniture. I’d like to share a few tips that might help you in everyday use.
First, for cleaning: I usually use a solution of lukewarm water with a few drops of vinegar essence, which I apply carefully with a well-wrung cloth. Vinegar has mild disinfectant properties and is biodegradable, but it’s important not to wipe with excess moisture. As my predecessor already mentioned, better avoid too much water!
Regarding maintenance: I’ve noticed that regularly oiling Hemnes furniture with natural oils (linseed oil varnish or walnut oil) does no harm—in fact, it keeps the wood flexible and protects it from drying out. This is especially recommended in homes with heating systems.
Another sustainable alternative is wiping the wood with a paste made from olive oil and perhaps a little lemon—it cleans the wood, smells pleasant, and conditions it at the same time.
If you need protection from sunlight or scratches, consider using light felt pads. I hope these ideas are helpful for you!
For sustainable cleaning of Hemnes furniture:
- Remove dust with a dry microfiber cloth
- Wipe with a slightly damp cloth and mild dish soap
- Immediately dry afterwards
- Do not use harsh cleaners
- Oil with natural wood oil every few months
This keeps the furniture clean and protects the wood.
CHENFAR schrieb:
Avoid excessive moisture, as too much water can cause the wood to swell. That is absolutely correct and important, especially with solid wood like Hemnes furniture. I would like to add that this can also roughen the paint or surface finish, which further reduces durability.
For cleaning, I recommend using a low-pore sponge to remove visible dirt; it captures crumbs or dust well without scratching the surface.
When focusing on sustainable cleaning, it is important to choose solvent-free and phosphate-free cleaning products – they are more environmentally friendly and help preserve the wood’s structure.
Regarding maintenance, I suggest occasional touch-ups using natural fiber polishing pads that gently polish the surface.
If edges or furniture parts appear dull, applying a thin layer of natural furniture wax (e.g., beeswax-based) can improve the protective finish and is safe for the environment.
