ᐅ How can I clean Billy bookshelves without causing scratches?
Created on: 8 Feb 2022 10:03
Matteo1
Matteo1
8 Feb 2022 10:03
Hello everyone, I have a fairly specific question: What is the best way to clean my IKEA Billy bookshelves without causing scratches or other damage to the surfaces? I want to avoid damaging the white painted or laminated surfaces with the wrong cleaning products or too aggressive scrubbing. Are there particular cleaning products, methods, or tools that are especially suitable? It would also be important for me to know whether it’s better to use wet or dry cleaning and which ingredients should be avoided altogether. Thanks for your expertise!
toril
8 Feb 2022 10:22
As a general recommendation for cleaning Billy shelves, use a soft, lint-free microfiber cloth. This is ideal for removing dust and light dirt without scratching the surface. Slightly dampen the cloth with clear, lukewarm water. Avoid harsh cleaning agents such as scouring powders, alcohol, or ammonia, as these can damage the foil or paint layer. Vinegar or strong all-purpose cleaners should also be avoided, as they can dull the surface or dissolve coatings.
After wiping with a damp cloth, it is advisable to dry the shelf with a dry cloth to prevent water spots. For heavier dirt, a cleaner specifically designed for plastic surfaces can be used, but always test it first on an inconspicuous area.
Summary:
- Microfiber cloth, barely damp
- Only clear water or pH-neutral cleaners
- No abrasive or harsh agents
- Dry wipe at the end
gasidney
8 Feb 2022 11:10
Only use a microfiber cloth, dampen it slightly, and wipe gently. Do not use any abrasive materials.
Davebla
8 Feb 2022 11:45
toril schrieb:
Avoid using harsh cleaning agents such as abrasive creams, alcohol, or ammonia, as these can damage the film or paint coating.
Good points, but I wonder if occasional gentle polishing with a suitable furniture wax really causes damage or might even enhance the protective layer. Has anyone had experience with this? Simply using water alone doesn’t seem ideal in the long run when trying to minimize fine micro-scratches.
Luciandi
8 Feb 2022 12:30
I also wondered for a long time how to clean my Billy shelves in the best way without them looking as if they had been sanded down after just the second cleaning. It’s really frustrating when small scratches become visible after a short time.
Fortunately, I found that using a combination of a microfiber cloth and a very mild dish soap works well. I use the cloth only slightly damp, do not scrub, but gently wipe in long, straight strokes. Then immediately polish with a dry cloth.
What I do not recommend at all are rough cloths or sponges, as they can cause permanent visible scratches. Sometimes I feel almost overly careful, but this really helps preserve the appearance.
By the way, for anyone worried about stains: vinegar or harsh cleaners quickly left unpleasant dull spots for me. This confirmed my concerns.
Benge5
9 Feb 2022 08:17
The recommendations made in post 2 align with my experience and the care instructions recommended by IKEA.
To clarify: Billy shelves usually have a melamine resin-coated surface. This coating is resistant to many common household substances but not to mechanical or chemical effects that can damage the protective surface.
Common mistakes include cleaning with too much water (moisture can penetrate the edges and cause swelling), using abrasive sponges, or cleaning agents containing solvents.
The following points are crucial:
- Cloths must be soft and clean, as dust particles can cause scratches.
- Clean only with a lightly damp cloth, not soaking wet.
- If necessary, use mild, pH-neutral cleaners, but no alcohol or ammonia.
- After wiping, dry the surfaces thoroughly.
Following these guidelines preserves the appearance and durability.
