I have several pieces of furniture from the IKEA Hemnes series, mainly dressers and nightstands, that I would like to clean gently and effectively. I understand that Hemnes is mostly made of solid pine wood and is usually coated with a protective varnish.
My main question is: How do you best clean your IKEA Hemnes furniture to preserve the wood surface while effectively removing dust, dirt, or small stains? Are there specific cleaning products I should definitely use, or is dish soap and water sufficient?
Additionally, I am interested in how to handle tougher stains without damaging the varnish, and whether you recommend any home remedies or specialized care products for this purpose.
I look forward to any tips, preferably with brief explanations of why certain methods are better than others. Thanks in advance!
enes59 schrieb:
Are there any specific cleaning products I should definitely use, or are dish soap and water completely sufficient?That’s a very good and valid question. The Hemnes series is mostly made from solid pine wood, usually protected with a clear lacquer or water-based varnish. Therefore, it’s important not to use harsh or aggressive cleaning products, as these can damage and fade the finish.
For daily cleaning, a soft, slightly dampened cotton cloth is perfectly sufficient. If you dissolve a small amount of mild dish soap in warm water, you can gently wipe the surface. Make sure to wring the cloth well to avoid standing water on the wood, as moisture can penetrate and cause swelling.
For tougher stains, I recommend first treating them with a soft eraser or a special wood eraser. This method is often more effective and gentler than chemical cleaners.
Alternatively, you can use a mild wood soap that is specifically designed for lacquered wood. However, avoid waxes, oils, or polishes, since Hemnes furniture is lacquered and these treatments can damage the protective layer.
Do you have specific types of stains you could describe in more detail? For example, greasy marks, ink stains, or water rings? Then I could assist you more precisely.
One last tip: it’s best not to use microfiber cloths with an abrasive texture, but rather soft, non-textured cloths to avoid accidentally scratching the finish.
Interesting discussion!
I think this is an important point to emphasize. Unfortunately, many assume that oiling or waxing wood is generally better, which is not the case here because the furniture is lacquered. This means the wood is protected by a waterproof layer that should not be moistened or removed.
It is also important not to clean the furniture with excessive moisture. While this may initially help to remove stains, over time it can cause joints or edges to swell—even lacquered surfaces can sometimes absorb moisture.
I usually use diluted neutral all-purpose cleaners (1:10 with water) and a soft cloth for Hemnes furniture. But I have been wondering: Are there any studies or reliable tests showing which cleaning agents are really safe for lacquered pine wood? Or are the recommendations so far mostly empirical and based on experience? I’m interested in this because I want to avoid damaging my furniture through incorrect care.
fidasi schrieb:
However, avoid waxes, oils, or polishes, since Hemnes furniture is lacquered and such care products can damage the protective layer.
pinbo schrieb:
I usually clean Hemnes furniture with a mild all-purpose cleaner diluted at a ratio of 1:10 with water and a soft cloth.Thanks for the tip, that sounds reasonable.
fidasi schrieb:
Do you have specific types of stains you could describe? For example, greasy marks, ink stains, or water spots?I do occasionally get small water spots because I often keep a glass of water on my bedside table at night, and sometimes greasy fingerprints, especially on the lower drawers.
Regarding the water spots, I was wondering if a special care product could remove them or if they tend to be permanent? Also, does the principle of “less water is better” still apply here?
Additionally, I was thinking whether white lacquered Hemnes furniture (some parts of my furniture are white glazed) should be cleaned differently than the natural-colored pieces. My understanding is that the same principle applies since the surface is still sealed with lacquer, right?
I would appreciate it if anyone has experience with this.
