I have a question regarding the installation of Ikea Pax drawers, specifically how to mount them securely and firmly so they remain stable even with frequent use. My drawers wobble slightly, and I feel they might become loose over time, which I definitely want to avoid.
More specifically, I would like to know if there are any special tips for fixing the drawers firmly and permanently, which fastening materials work best (e.g., additional screws or special brackets), and if there is anything to consider regarding the installation frame.
It would also be helpful if anyone has experience with installing the drawer slides in a way that distributes the load optimally and ensures the whole system is as durable as possible.
Thanks in advance for your advice!
barEsperan17 Jun 2020 09:57Hello Rotar,
I would recommend aligning the drawer slides precisely and tightening the original screws securely. Small metal brackets on the inside of the drawers can also be helpful if there is any wobbling. Make sure the connections between the frame and the slides are firm. This is usually enough to ensure stability.
Hello Rotar,
I would like to take a closer look at this topic, as installing PAX drawers involves several important details:
1. Alignment of the drawer slides: Use a spirit level to ensure they are perfectly horizontal. Even slight deviations can cause looseness and wobbling.
2. Check the screws: The included screws are designed for standard use, but often it helps to replace them with slightly longer wood screws if the cabinet material allows.
3. Add reinforcements: Small angle brackets on the inside can help if the cabinet is not completely stable. Attach these to the back panel and the drawer front to prevent any movement.
4. Inspect material quality/cabinet: Sometimes the issue is caused by an unevenly manufactured cabinet. A small amount of glue or filler applied at the contact points can help here.
Summary: Careful alignment, quality screws, reinforcements if necessary, and inspecting the cabinet are the key elements.
I hope this helps you!
Hello Rotar,
to address the topic of 'drawer mounting in Ikea PAX' accurately and reliably, here is a detailed overview including technical tips:
First, you need to understand the mechanics: Ikea PAX often uses metal runners (full-extension or partial-extension slides) that already provide a certain level of stability. The drawers themselves are usually made of particleboard with a thin melamine coating, which means that direct, repeated pressure points can be critical.
1. Load distribution: It is important to distribute the load across the entire runner. If the drawer is fixed at only a few points, this leads to increased wear and wobbling. Therefore
- check all screws on the runners to ensure they are properly tightened.
- avoid screws that are too short or do not fully engage the threads.
2. Reinforcements: Use metal brackets on the carcass sides to minimize lateral movement and secure the runners more firmly.
3. Assembly of the carcass: Make sure to set the PAX carcass completely level and square. Small misalignments will increase drawer wobble. Use a spirit level and align everything carefully.
4. Additional fixing materials: I often use small plastic wedges or spacers to perfectly align the runners.
5. Permanent fixation: After adjustment, secure the screws with threadlocker (e.g., medium-strength threadlocker) so they do not loosen with use.
6. Care with repeated assembly: If drawers are removed frequently, screws should be checked regularly because the particleboard material tends to loosen over time.
One more question: Are you using the original drawer slides or have you installed third-party components? This significantly affects durability.
I’m happy to assist with further details!
jelite schrieb:
Install reinforcements: Small angle brackets on the inside can help if the cabinet frame is not completely stable.Thank you for the detailed response, jelite! Could you or someone else explain a bit more precisely how to install such angle brackets? I have found it difficult so far because the cabinet frame is quite tight.
Also, do I need to add extra fasteners on the drawer front, or is it enough if the drawer slides are properly installed? Or are the angle brackets mainly intended as an addition for the cabinet frame?
The PAX cabinet frame is now standing very straight, I have checked this several times. It’s really about securely fixing the drawers themselves.
Rotar schrieb:
Could you or someone else explain in more detail how to install these angle brackets?The angle brackets are used to reinforce the connection between the drawer slides and the cabinet. Basically, you attach them on the inside of the cabinet where the drawer slides are installed. Usually, you can drill small pilot holes and secure the brackets with short screws.
Rotar schrieb:
Do I need to add extra fasteners on the drawer front, or is it enough to have the drawer slides properly installed?The drawer front is typically secured with specific fastening systems from Ikea (clips or screws). These are sufficient to hold the front firmly in place. Additional angle brackets are mainly intended for the cabinet to stabilize the drawer slides and the frame, making the entire unit more secure.
It is important that all connections are tight, and to avoid material deformation caused by moisture or improper installation.
