ᐅ How do I securely mount Ikea Metod wall cabinets on rigid walls?
Created on: 3 Feb 2020 08:23
Koleklo
Hello everyone, I am currently facing a challenge with installing IKEA Metod wall cabinets in my new house. The walls are very rigid – concrete with a relatively smooth surface or possibly drywall over a concrete wall underneath. My main question is: how can I securely and permanently attach the Metod wall cabinets to such rigid walls without the brackets or anchors coming loose later or the cabinet sagging? I want to avoid the cabinet becoming unstable, as it will be quite heavily loaded. Are there specific anchors, screws, or installation methods you would recommend for these cases? I appreciate any tips, including advice on drill bits or tricks for wall preparation! Thanks in advance.
Lisele
4 Feb 2020 09:03
I recently had a similar experience when mounting my kitchen wall cabinets on a concrete wall. At first, I was quite worried about how to make it stable, given the weight and length of the cabinets.
What helped me was a calm approach and repeatedly checking the drill holes. If you notice while drilling that the drill bit is no longer in concrete but possibly in a cavity or drywall, it’s better to reposition the hole in that spot.
In the end, I was able to install very secure mounts using 10 mm (3/8 inch) metal expansion anchors and suitable screws in the concrete. It was also important to thoroughly blow out the holes and vacuum them before inserting the anchors, as this improves the grip.
I fully understand your need for security—I was uncertain at first too. But with proper preparation, you feel much more confident and worry less about the cabinets falling. It’s worth persevering.
TRA33
4 Feb 2020 11:44
In general, always choose metal expansion anchors for concrete, as they are rigid and durable. Important: Clean the drill hole with a vacuum and tighten the screws securely. Screws should be long enough to ensure sufficient thread engagement within the anchor.
nofomu
4 Feb 2020 15:10
Big tip: Pay attention to the load ratings of the anchors. For Ikea Metod cabinets, small plastic anchors are usually not sufficient; you need metal expansion anchors or heavy-duty anchors that are at least 8-10mm (0.3-0.4 inches) in diameter. Choose the appropriate drill bit, drill, clean the hole, insert the anchor, and securely tighten the screws.
Liduta
5 Feb 2020 08:33
I am summarizing the key points here for everyone who has similar questions:
- Check the wall with a multi-detector for cables, studs, and metal.
- Drill using a suitable hammer drill and masonry drill bits (6-8 mm (1/4–5/16 inch) or 10 mm (3/8 inch), depending on the anchors).
- Use high-quality metal expansion anchors or heavy-duty anchors.
- Clean the drill hole thoroughly after drilling to ensure long-lasting hold.
- Screws should be long enough to properly secure the anchor.
- Always drill through the gap between drywall and concrete to distribute the load onto the concrete.
- After installation, test the cabinet to make sure it is firmly fixed and does not move.
This will reliably prevent the fixings from loosening later. Every step is important; do not skip any!
jordanvin
5 Feb 2020 13:26
Wow, these are really great answers! I just want to emphasize that you shouldn’t be afraid – with the right tools and anchors, this is not a big problem at all! You can definitely do it, and I’m looking forward to hearing how it goes for you! Good luck, it will be great!
