ᐅ How do I secure Ikea Metod cabinets to walls with varying levels of stability?
Created on: 28 Jul 2020 16:03
lumogeHello everyone,
I am currently facing the challenge of how to securely mount my Ikea Metod kitchen cabinets on walls with varying stability. Specifically, I have different wall types: a load-bearing concrete wall in the kitchen area, drywall (plasterboard) walls in adjacent rooms, and some brick walls that seem somewhat fragile.
My main question is how to choose the right anchors, screws, and fastening methods for each wall type to ensure the cabinets hold safely without damaging the wall or risking the cabinets falling down over time. Important factors also include handling during installation (whether mounting alone or with a partner) and the risk of permanently weakening the wall at the mounting points.
I would appreciate concrete advice, preferably with recommendations on which materials work better or worse, and detailed guidance on how to proceed during installation. The combination of different wall types makes this a bit more complex for me. Thanks in advance!
Basically: For concrete walls, use heavy-duty anchors and suitable screws. For drywall panels, use special cavity anchors such as toggle bolts or metal expansion anchors. For brick walls, cylindrical anchors with sufficient length are best. Always choose anchors according to the wall’s load-bearing capacity.
stefangla28 Jul 2020 17:14Hello lumoge,
I’m happy to give you a more detailed overview:
1. Concrete wall:
- I recommend using mechanical heavy-duty anchors (e.g., metal expansion anchors or chemical anchors).
- Drill using a drill bit that matches the diameter of the anchor.
- Pay attention to the mounting height and distribute the fixing points evenly.
2. Drywall (plasterboard) wall:
- Cavity anchors are the best choice here, preferably metal toggle anchors.
- Important: Check the thickness of the drywall panel and the material behind it.
- If the drywall is too thin, it’s better to install a counter batten or fix the cabinet to load-bearing wooden studs.
3. Brick walls (load-bearing or non-load-bearing):
- Use high-quality universal anchors that grip well in porous material.
- If possible, choose longer screws for better anchoring.
Installation tip:
- First create a mounting template to transfer the drill points precisely.
- Use a level and double-check measurements before drilling.
- Handling the cabinets is best done by two people, which allows safer work and reduces the risk of damage or incorrect installation.
Common issue:
- Anchors that are not strong enough or too few fixing points often lead to pull-out failures.
- Avoid placing anchors in cracks or crumbly bricks.
I hope this helps!
1. Concrete wall:
Installation tip:
Common issue:
I hope this helps!
stefangla schrieb:
Assembly tip:
- First, create a mounting template so you can transfer the drill points accurately. Great tip! It saves a lot of stress and “test drilling” later on.
Here’s a little hack from me: If you have drywall panels that don’t feel very sturdy, just tape around the drilling spot with some painter’s tape. This helps prevent chipping and gives you better control.
And: Don’t be afraid of drilling! With the right tools, it’s actually fun.
I think we tend to overestimate the standards for Ikea Metod cabinets a bit. These units aren’t really heavy, and often it’s enough to mount the cabinets securely at the load-bearing points of the wall; the rest can be reinforced with brackets.
I see it differently. In solid drywall constructions, I find such anchors to be excessive – sometimes a good plastic adhesive or self-tapping screws are sufficient.
My advice: Don’t make it too complicated; drilling multiple holes and experimenting creates more holes than support.
fiman schrieb:
For drywall panels, use special cavity anchors like toggle bolts or metal expansion anchors.
Hello lumoge,
to answer your question: Attaching Ikea Metod cabinets to different wall types indeed requires different approaches. I will explain the basics and provide practical tips:
- Concrete wall: This is the easiest since these walls can carry a lot of load. Use heavy-duty anchors (e.g., expansion anchors or wedge anchors). Drill a hole deep enough so the anchor sits fully. Screw a hex-head screw (pay attention to length) into the anchor.
- Drywall (plasterboard) wall: As already mentioned, the load capacity here is critical. Be sure to use metal toggle bolts or alternatively spring toggle anchors, as they distribute the load better. Most drywall panels are only load-bearing where there are wooden or metal studs, so if possible, fasten directly to a stud.
- Brick walls: Bricks have uneven load-bearing capacity. Use special universal anchors that hold well in hollow or solid bricks. Again, longer anchors that reach deeper are better.
General tips:
1. Consider the total weight of the cabinets including contents.
2. Take into account the relationship to countertops and appliances (e.g., stove).
3. Better safe than sorry: more fixing points are better than fewer.
4. Installation with two people makes securing the cabinets easier and prevents damage.
If you have more questions about choosing anchors and screws, feel free to ask again.
General tips:
