ᐅ How can I assemble IKEA Hemnes furniture quickly?
Created on: 15 Feb 2020 08:19
duncan8
duncan8
15 Feb 2020 08:19
I recently ordered some furniture from the Ikea Hemnes series and now face the challenge of assembling it as quickly and efficiently as possible. Since Hemnes furniture is known for consisting of many individual parts and various fasteners, I want to avoid wasting time or making mistakes that could later affect the stability or appearance.
Specifically, I’m interested in proven tips for speeding up the assembly process: Is there an ideal order for the steps? Should the assembly instructions be followed strictly, or is an alternative approach worthwhile? Do you use any particular tools or techniques to accelerate the build?
It would also be helpful to know about common pitfalls or frequent mistakes with Hemnes furniture, so I can prepare accordingly.
Thanks in advance for your practical advice!
jelite
15 Feb 2020 09:07
Hello duncan8,
I am quite familiar with the Hemnes series and would like to give you a structured guide for quick assembly:
- Preparation: Sort all parts according to the instructions and check that everything is included. This will help you avoid searching for parts later on.
- Tools: It’s best to have a cordless drill with a suitable Phillips bit, a rubber mallet, and a screwdriver ready.
- Step-by-step assembly: Follow the instructions carefully, but don’t follow the order rigidly if smaller steps can be done simultaneously.
- Common mistakes: Make sure to fully insert all wooden dowels before joining the parts, otherwise the pieces won’t fit together properly.
In summary, thorough preparation is key to saving time. Do you already have experience with these types of shelving units?
Aimee
15 Feb 2020 12:03
Hey,
I would say the important points are:
- Sort parts in advance
- Work through the manual step by step
- Use a cordless drill
This way, you can avoid problems and save time.
laume
15 Feb 2020 14:27
Hello duncan8,
I want to add my experience since I have assembled the Hemnes build several times. Here are a few tips that might help:
- Take some time to read through the entire instruction manual before starting assembly. Some steps seem easier once you’re familiar with them in advance.
- Don’t skip sorting all the screws and wooden dowels. It’s common to mix up screws, which can make the assembly more difficult.
- If possible, work with a partner. Especially with wide components like cabinets, this can save a lot of time.
- Pay close attention to the alignment of the panels when joining them. If a hole doesn’t fit, it usually means there was a small error in positioning.
- Have you checked if you have all the connectors ready, or would you like tips on how to quickly replace or improvise missing parts?
I hope these suggestions help! If you’d like, I can also provide more detailed advice on specific pieces from the Hemnes series.
duncan8
16 Feb 2020 07:55
jelite schrieb:
Sort all the parts according to the instructions and check if everything is included.
I usually do that, thanks for the reminder. So far, I haven’t had any major issues with other Ikea furniture, but the Hemnes series does seem more complex in terms of the number of parts.
laume schrieb:
Take some time to read through the entire manual before starting the assembly.
I will definitely do that.
Regarding tools: I actually have a cordless drill that I’ve only used for rough work so far. Should I use a manual screwdriver for finer adjustments instead?
And secondly: Which assembly steps in Hemnes furniture can be done in parallel to save time?
Looking forward to more tips!
liste
16 Feb 2020 10:14
duncan8 schrieb:
Which tasks can be done in parallel when assembling Hemnes furniture to save time?
Interesting question! In my opinion, it largely depends on the specific type of furniture, but generally, the following can be said:
- Prefabrication of components: If there are multiple identical parts, such as shelves or side panels, you can prepare and paint them (if needed) in parallel to speed up the later assembly.
- Pre-inserting screws: Some steps, like screwing into individual panels, can be done in advance and help accelerate the final assembly.
However, I’m skeptical about gaining much time solely by parallelizing the assembly itself, since the construction often depends on previous steps. So be careful not to cause more mistakes this way.
I also think it’s important not only to work quickly but also carefully. IKEA flat-pack furniture like Hemnes should be as stable as possible; otherwise, speed won’t be very useful.
