Hello everyone, I’m currently working on a project to refresh the look of an IKEA Hemnes dresser. I have the idea to cover it completely with fabric to give it a more personal and perhaps cozier touch. My question is: How can you properly and durably upholster an IKEA Hemnes dresser with fabric so that the covering fits neatly, doesn’t wrinkle, and also covers the edges and curves well? Are there proven techniques or materials to best secure the fabric without damaging the surface? I would really appreciate it if anyone could share relevant experiences or tips – including advice on necessary tools, adhesives, or preparation steps. Thanks in advance!
As many have already mentioned, the right adhesive is crucial. Regular fabric glue is often not suitable for furniture because it cannot withstand the stress. I prefer to use a sprayable contact adhesive that becomes tacky on both sides for a short time.
Since a Hemnes dresser has many corners and edges, simply gluing the fabric on can cause many wrinkles. I cut the fabric at the corners to make it easier to lay and gently warm the edges with a hairdryer. Heat makes the fabric more flexible.
For durability, you can also add invisible dowels or small glue spots in less visible areas, especially if the dresser will be subjected to heavier use.
I would like to add to my comment: When covering the HEMNES with fabric, be sure to allow time for preparation – cleaning, sanding, and test fitting.
It is also worth treating the fabric with a textile spray before final application, which makes the fibers more flexible and protects against dirt. A water-repellent finish can also increase the durability of the upholstery.
Sometimes it helps to glue a thin foam padding under the fabric if you want a slightly softer feel – for example, thin foam or quilted batting.
Have you already decided which fabric you want to use? Sometimes the type of material makes the biggest difference.
Thanks to everyone for the detailed and practical tips – I really appreciate it!
[@Dilen, post: f6j1y0] Thank you for the thorough explanation, especially the advice about lightly sanding and the tip to use heat to stretch the fabric – I find both very helpful.
I’m actually planning to use a cotton blend with a bit of stretch to make it easier to fit around the edges. I will also experiment with spray adhesive, possibly combined with staples at the corners, as you recommended.
However, I have one more question: What is the best approach for dealing with drawer fronts, which are movable – should I cover them separately and then reattach, or work directly on the front? So far, I haven’t managed the corners of the front panels very well.
Looking forward to your opinions!
