Hello everyone, I have a problem that I’m sure some of you know: How can I stabilize or repair wobbly Malm drawers from Ikea? My drawers wobble a lot when opening and closing, and sometimes they even get stuck because the runners don’t seem to be properly aligned anymore. These are the models with the extendable metal slides, but I haven’t found any loose screws. The drawers are not overloaded, yet everything moves too much and feels unstable. I don’t want to buy complete replacement parts but would rather try to repair or adjust them myself. Are there any proven tips on how to make the drawers stable again without completely removing them or using Ikea’s service? Thanks in advance for your advice!
Hey, great thread! I know this all too well—those wobbly Malm drawers can be really annoying. :-) Often, the problem is that the small plastic clips on the metal drawer slides have loosened or worn out. With a bit of care, you can carefully adjust or replace them. If you pull the slider out of the track and check the mounting clips, you can often see an improvement.
Also, check if the screws holding the drawer slides to the drawer are really tight—sometimes they look tight but are slightly loose because the threads are worn. A little wood glue or a thin piece of cardboard behind the screws can sometimes help improve the grip. 😉
Hope this offers a little help to get started!
Hello dewey37, I understand how frustrating this can be. Wobbly Malm drawers are a common issue that isn’t always easy to solve at first glance.
One important point is that while the metal runners are sturdy, the smaller adjustable plastic components in the drawer slides can wear out or break over time due to constant use.
My tips:
1. You should fully pull out the drawers and carefully inspect the runners – also check for microcracks or deformations.
2. Sometimes it’s enough to slightly push the drawers back from the inside and click the plastic clips back into place.
3. If the runners are completely loose, you can often improve the fit with small, matching screws or even thin plastic spacers.
4. A very light drop of silicone oil on the runners can also prevent sticking without affecting stability.
If the screw threads in the wooden drawer no longer grip, you can try filling the holes with toothpicks and wood glue before screwing the screws back in. This restores stability without needing to buy new parts right away.
I hope this helps! I can provide more details if needed.
My tips:
Wow, I can’t agree that you can really repair Malm drawers much without buying replacement parts.
And regarding
I’ll throw out a provocative idea: Malm drawers are not designed to be repaired—they are meant to be replaced. Anyone constantly tinkering with them wastes unnecessary time and money. Better to upgrade to sturdier furniture. 😉
But I’m curious if anyone has practical experience with repair options besides replacing the plastic parts.
raulso schrieb:– That sounds too optimistic to me. These small plastic components are quite cheap, and if any are missing or broken, DIY fixes won’t help anymore.
“that the small plastic clips on the metal runners have loosened or worn out”
And regarding
BeAndrea schrieb:: The stability you’re trying to achieve this way is really a second-best solution in furniture construction. It would be more reasonable to rely on original replacement parts; otherwise, it won’t hold up for long.
“filling the holes with toothpicks and wood glue”
