ᐅ How can Malm furniture be made more durable?
Created on: 23 Apr 2019 08:37
BIRGITT
I am currently looking into ways to make IKEA Malm furniture more durable, as I use several pieces daily that can be quite delicate. I am particularly interested in practical solutions that can be implemented easily without much effort.
I am thinking about methods to protect the surface, as well as reinforcements to keep the drawers or carcasses more stable. Maybe there are special maintenance products or tips regarding the right screws or installation techniques.
Does anyone here have experience or advice on how to make Malm furniture more robust over time without compromising its appearance or requiring too much effort?
I look forward to your input!
barsar
23 Apr 2019 13:07
Regarding drawers: If the slides are loose or no longer operate smoothly, simply check the rails and consider installing new ball bearing slides. These provide better durability and smoother movement.
Additionally, self-adhesive edge protectors on the exposed edges of the drawers help prevent chipping.
PLOMA
24 Apr 2019 07:38
RON57 schrieb:
To retighten the screws, I also recommend checking all connections every 2-3 months with a small Phillips or Allen screwdriver.
Exactly, that is extremely important and often underestimated. In addition, I would add that you should not only retighten but also check the dowel holes. Particleboard furniture tends to swell or loosen quickly with frequent use.
A good idea is to apply a little wood glue into the dowel holes if you can disassemble the furniture. This will increase the overall stability.
BIRGITT schrieb:
Has anyone had experience with primer or undercoat for these types of furniture foils?
Unfortunately, many common primers do not adhere well to foils or can cause blistering. A bonding agent, such as a special plastic primer, is important.
I’m happy to help if you are starting a specific project.
NISAN
24 Apr 2019 10:52
Hello Birgitt,
I can totally understand how frustrating it is when the furniture isn’t as sturdy as you expected. I feel the same way with my furniture – it can make you feel quite helpless.
I really like how everyone here shares their experiences and responds to your specific situation.
If you’re doing a quick check or maintenance, try to see it as a small break or enjoy it with some music :-) It’s a bit of work, but you’ll feel rewarded afterward.
Keep at it, and feel free to reach out anytime if you have any problems 🙂
Sometimes it also helps to get feedback from the manufacturer’s customer service, especially with recurring issues. Have you tried that yet?
Peone
24 Apr 2019 11:39
BIRGITT schrieb:
The idea of using varnish sounds interesting, but I’m a bit concerned that the appearance might change or the varnish might not adhere well.
That’s a valid concern. I have treated cabinet bodies myself with a special polyurethane varnish designed primarily for furniture laminates. It’s important to thoroughly clean the piece, lightly sand the surface, and prime it with a suitable adhesion promoter.
When these steps are followed, the appearance changes only minimally, and the finish usually remains slightly matte. The durability is actually much better than with wax alone. However, applying it takes some patience and requires several thin coats, especially on laminate surfaces.
If you like, I can share the exact products I used.
